Alaskan
Riese & Muller Delite Mountain Ebike Many Extras Burley Coho Trailer...
ORIGINAL EQUIPMENT • Fox Front Fork & Rear Shock (OEM entry level) • Bosch CX Gen 2 Motor (Class 1 Pedal Assist - Maximum Assist 20mph) • 2 - 500 Watt Hour Bosch Batteries • Bosch Intuvia...
seattle.craigslist.org
- Fox Front Fork & Rear Shock (OEM entry level)
- Bosch CX Gen 2 Motor (Class 1 Pedal Assist - Maximum Assist 20mph)
- 2 - 500 Watt Hour Bosch Batteries
- Bosch Intuvia Display
- 15 Tooth Front Chain Ring
- Shimano 11-42 Tooth Cassette
- X-Fusion Dropper Post
- No Lights - No Fenders - Basic Flat Pedals
- Fixed Angle Stem
- Strait Mountain Bike Style Handlebars
- Schwalbe Knobby Knick Tires
- 4 watt Bosch Charger
UPGRADES & EXTRAS
- Bikespeed-RS Speed Delimiting Dongle - installed in Motor - Allows Pedal Assist Without Speed Limitations
- Fox Float DPS 3-Pos-Adj Performance Rear Shock installed new in 2021
- Fox Float Stepcast 3Pos Kashmina Factory Fork installed new in 2021
- Bosch Nyon Display - Custom Data Fields - GPS Mapping - Smart Phone Integration - Heart Rate Monitor Input
- 18 Tooth Front Chainring
- Sunrace 11-46 Tooth Cassette
- KMC X11EL Ebike Rated Chain
- Pedaling Innovations Catalyst Pedals
- SKS Bluemels 75 Fenders (takes about 15 minutes to remove or replace them)
- Ergotech Swell Ahead Adjustable Angle Stem
- Supernova M99Pro Headlight with Low Beam, 1600 lumen High Beam, Auto Daytime Mode
- Supernova TLP Pro Rear Light
- Schwalbe Johnny Watt Tires 27.5 x 2.8 - Suitable for Paved Roads, Logging/Fire Roads (with good flat protection)
- Tubolito Tubes (light weight and puncture resistant)
- Surly Terminal 30 Degree Swept handlebar
- Hexlox security inserts on axles, stem, handlebars, seat clamp - Prevents component theft
- Ergon Bio-Cork Grips
- Spurcycle Bell
- Rechargeable Horn
- OEM Suspended Cargo Rack (Mounts with 3 Bolts)
- PNW Coast 100mm Dropper Post with 30mm Air Shock (internally routed)
- Shimano IceTech Sintered Metal Brake Pads
- Shimano IceTech Brake Rotors (202mm front 180mm rear)
- Wolf Tooth Dropper lever
- ABUS Big 6000 Folding Lock
- Busch & Muller 701 Rear View Mirror
- Hidden Motion Sensor Alarm With Key Fob Control
SPARE PARTS & EXTRAS
- Bosch Motor Repair kit (all new bearings and gears) Unused
- Original Schwalbe Knobby Knick Tires 27.5 x 2.8
- Tannus Armour Tire Liners (reduces flats)
- Three sets of unused Shimano IceTeck Brake pads
- Two Neoprene - Battery Insulation Covers for cold weather riding
- Original front and Rear Through Axles
- Hexlox Rear Axle
- Lightly used Shimano 11-46 Tooth Cassette
- 15,16,17, & Spare 18 Tooth Front chainrings
BURLEY COHO TRAILER
- Dry Bag For Contents
- Two Water Bottle Holders
- Suspended Single wheel
- Special Easy On/Easy Off Axle for Connecting Trailer
- Rear Pannier Rack
- Trunk Bag With Small Drop Down Side Bags
- Great On Or Off Road
