TomD
No PAS is a head scratcher. Throttle only / pedal input is ignored? I guess if you want something more akin to a motorbike than an ebike.
I'm not sure I'm convinced there is much practical redundancy either. If you consider the assist side chain will be most likely to break, can't see pedaling this bike home without assist unless you're on flat ground. It's different than a rear hub where motor failure (I'd think far less likely than motor assist chain breakage) is going to be the pedal home scenario.
Edit: to clarify, I'm thinking of the dominant scenario where redundancy comes into play. On a rear hub the dominant scenario would be chain breakage (more likely than motor failure) so dominant redundancy is more useful than not. On a dual chain setup, the dominant scenario is motor assist chain breakage, and dominant redundancy is of much less practical use.
