The question ... does the hub adapt to all the profiles of electric cycling?NO.
There are no hub engines in emtb.
The only one that serves all cycling profiles is the mid-drive.
The only one with 250w or 350w that makes hillclimp of up to 40 degrees is mid-drive,
Meets all hillclimp / downhill / flat terrain profiles.
The mid-drive keeps the center of gravity in the center
The mid-drive has more efficiency per kilometer, spending less battery and increasing the range of autonomy.
¿Can a 250w / 350w hub make hillclimp 40 degrees?
Need power of 750w hub or more.
¿Does the motorcycle have a engine on the wheel or on the frame?Motorcycle=engine frame.
A hub needs a structurally reinforced wheel , nor does it allow such essential rear fox and and does not allow jumps from rock to rock.
The structure and bearings of the hub wheel would break in the EMTB sessions.
The hub with great powers needs structurally reinforced wheel +++= wheel 27,5+ /big.
you in a 700x25 wheel road ebike you can put up to 750 w mid-drive in the frame but with 750w hub in the rear wheel you need structural reinforcement .......
the hub profile is of city, road and compact earth.Commuter to work ,Router,Travel.The mid-drive
has that same and the extreme versions of emtb and road 700x 25 wheel.
If you have to repair a puncture in the rear wheel, the mid-drive is faster than the hub and you need less tools or even without tools with fast closing clip, with the hub you need to disconnect the cable to the hub.
