Mr. Coffee
- USA
- City
- A Demented Corner of the North Cascades
DD hubs - yes, as long as you keep it dry. Geared hubs - not so much.
But then, 1.5-2K miles is not unheard of, even for a geared hub. Depends on how and where you ride, too.
Bafang hub costs from $200 online and is not terribly difficult to swap with exactly same motor that has just died. Bafang mid-drive costs roughly 2 times more. Bosch... let's not go there...
After 2K miles the cost of battery replacement will dwarf the "hub worries", if battery will even last that long.
I have a Pedego Interceptor with over 3k miles on the battery and the hub motor. Both are going strong (battery holds 15-20 percent less charge after approximately 150 charge cycles).
