pyorahullu
- Europe
Heye
You maybe have noticed that the bearing on rear wheel on disc brake side is por protected from dirt going into it. I have a solution to grease the bearing and prevent dirt going into bearing.
1. Remove rear wheel and ewerything from disc brake side ( including plastic cable protector, no disc)
2 buy a seal 16x30x4,5 mm
3. Put grease into the bearing ( there is a small hole)
4. Put grease to the seal and axel.
5. Insert seal in place
Notice. 5 mm thickness is too much
Here example of the seal
