In my brief time in the saddle, I have just a few observations:
The "thrust" using throttle alone feels "weaker" than I expected. It is sufficient (and I intend to primarily use pedal assist), but even in PAS 1, the thrust from pedaling feels quite good (maybe even a little much).
Previous reports claiming the bike is not just quiet, but silent are right on the money!
Fit and finish look excellent.
I do have a nit to pick though.... I prefer my brake levers to be angled down so as to be easier to reach (see Trek bike pic in first post). Unfortunately, there is significant interference with the throttle wire, brake lever assembly, and quick shifter that prevented me from positioning the brake levers at my preferred angle. This is a minor issue, and if it bugs me too much, I will loosen everything up on the right handlebar, and attempt to reposition the throttle, such that the wire comes out from the bottom (instead of the front), which should provide enough clearance for the quick shifter to be positioned properly, and the brake levers to be angled down enough for my preference. Thinking about it, maybe the rotation I would want for the throttle, would be "up", resulting in the throttle wire coming up from the top....
In my opinion, the LCD display mounting could be improved. For a "permanent" mount (as it is now), clamps on both sides would be more stable, and ensure the display does not tilt to one side (as is visible in one of Court's video reviews). Better yet, a quick release mounting bracket would be a major improvement.
I did notice a little brake squeal, but I'm assuming that will be reduced when the pads and disks "seat" against one another (bed).
Only two miles, and only in my neighborhood.
It is beautiful today where I live but I'm stuck at work....
Oh, and a question:
Does powering off from the handlebar (fully off) actually turn of the battery as well?
Thanks.
More opinions and observations when I get to actually put some miles on the Dash.....
