Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
I am a fan of gadgets and statistics. I'd love to have an e-bike display to tell me everything I'd like to know, for instance my cadence, my power input, and I'd like to configure Pedalling Assistance Support Levels with my smartphone. How naieve I was!
See this review of Bosch displays. Most of them seem rather hopeless and limited, and offer not very much of configuration options from smartphone. The latest Bosch Smartphone Hub is not mentioned here. Riese & Mueller promise miracles with that latest device but... Fancy you would like to purchase the Bosch ABS braking option from R&M. Can you? No, if you opt for the Smartphone Hub. You need to choose the Kiox (that is somewhat limited) to use the ABS braking.
The situation becomes even more hopeless if you want to buy an S-Pedelec, the Class 3 e-bike. Here, the options are even more limited. With R&M HS models, you are at best limited to Kiox display which does not offer 100% Bluetooth configuration capability. How strange.
Probably, the most advanced of displays/Control Units is the Specialized Turbo Connect Display (TCD) that really works with a smartphone and ANT+ devices. Mission Control App works with the TCD and BLEvo works with TCD. The problem is, these displays are available on Turbo Levo and Kenevo and perhaps the new TCD-W (wired) works as well. However, TCD-W is unavailable for most of Specialized Speed E-bikes.
I despised the BLOKS display found on older Turbo Vados since that display cannot work with Mission Control or BLEvo. Was I right? Not necessarily. The dreaded BLOKS display at least tells you your cadence, shows the relationship between your and bike's power input, calculates kilocalories you burn and performs all other functions of a regular bike computer. And most importantly, it shows the battery level in percent. Not that every e-bike display in the world can show anything more than bars.
I am green. I do not know very much about e-bike displays. Tell me your experience!
