Trail Cruiser
My BBSHD at 2,300 miles was making chirping noise. I lubed the chain, one link at a time. I also lubed the pedal crank shaft bearing by allowing the oil to seep though while the ebike is tilted to the right side. Everything went good after that until after a couple hundred miles when chirping noise came back again. It became louder when the assist level was higher.
I was about to open up my mid drive motor and lube the internal gears and bearings. However, since I also noticed that one of the chain link pin was dislocated and rubbing, I thought of putting a new chain first before opening up my BBSHD.
Lucky for me, all the noise disappeared with the new $14.00 chain.
The take home lessons for me were:
1. The original chain lube that came with the chain lasts more than a thousand miles.
2. Relubing the chain can only last few hundred miles before noise comes bask.
3. Relubing the chain does not guaranty complete seepage of the lubricant into each rollers plus since the lubricant is not as thick, it also easily leaves the rollers dry.
4. Put a new chain first (it's easy and not that expensive, got mine for 14 bucks at ebay) to see if the noise resolves before opening up and potentially making mistakes in handling your mid drive motor unit.
