Chain Lube for Giant E Bike, Quick-E+, any suggestions on brand of chain lube to use.
Gazza1977
Hi,
Just received my new Giant Quick-E+ 2018 bicycle, very excited.
Cape Town South Africa, will be cycling in bicycle lane as a commuter to work.
Any suggestions on the best chain lube for my E Bike.
Many thanks,
Gary Laue
My two favorite bike lubes:
https://boeshield.com/bike/
http://www.finishlineusa.com/products/chain-lubricants/dry-lube
Both work great on chains, but I've found the Boshield works better in other areas like cables and derailleur pivot points. Both get great reviews.
One invaluable tool for chain maintenance:
https://www.parktool.com/product/cyclone-chain-scrubber-cm-5-2
Available on Amazon. Often comes with cog cleaning brush/scraper.
You can use most any household, automotive degreaser. I like Spray Nine. You want to be very careful the degreaser is paint and aluminum safe.
Thanks so much J.R, much appreciated. Invaluable advice.
Not to mention that Boeshield also works very well applied to electrical connections to help disperse moisture and corrosion. It was developed for Boeing thus the Boeshield.
I have been using it for years and never fully clean/soak the chain with any solution, just reapply and wipe down after pretty much every ride and get many miles out of my chains. In all conditions BTW. Wet, dry and below freezing.....
@Gazza1977 We are big fans of the Muc-Off line of products. We use these lubricants in our workshop as well as sell them to our customers. What's important is to select the correct lubricant for the conditions you will be riding in.
  • Dry Lube for Dry conditions:
  • Wet Lube for Wet conditions
  • Low temp Lube for cold winter riding
If you are riding in wet / winter conditions you should also consider getting a tube of dielectric grease and putting a thing coat on the connectors between the battery and the bike. This is a know weak point on Giant bikes and it's a great preventative maintenance tip.
https://shop.scooteretti.com/collections/electric-bike-maintenance
hope this helps,
Will
hope this helps,
Will
Thanks for the advice Will.
Thanks for advice.
Among products you might be able to buy in S. Africa, is SUS32 (SAE 5) hydraulic fluid. Buy the generic kind that doesn't meet the specs of John Deere, Catepillar, New Holland etc. No additives. Comes in gallons from the farm or industrial supply. Use a pump oiler. I lube my chain, shifters, cables, brake pivots monthly. I leave the bike daily out in the rain & snow, parts don't rust or bind.
Great, thanks for the advice.
I use standard 20W50 (API SL/CF; ACEA A2/B2) motor oil
A 4 litre bottle should last 10+ years
To date my current chain & cassette driven by a Shimano E8000 motor has achieved 7,711km
