Changing out the 3.3" CST tires with 4.0" Mongoose tires. Struggled more than any tire I've installed, but got it on the rim with the tube and Tannus secure inside and on the rim. I inflated the tube slightly beforehand and it was fine. After installing the tube and getting the tire fully mounted, I can't get air into the tube. I've got a good hand pump and an air compressor, but both have trouble blowing into the valve. They either get blocked or blow outside the valve. Again, the valve worked fine before install and the pin doesn't seem stuck. The pumps test fine on other tires.
Now it seems almost impossible to get the Mongoose off the rim to inspect the tube. I'll take it to a shop tomorrow, but any suggestions in the meantime? Anybody run into a similar issue with the valve? Any tricks to getting a 4" tire off the rim beyond the typical YouTube stuff? My levers are bending and snapping.
Thanks for any ideas or suggestions.
