You can do that. On the new controller the throttle amps are tuned down so they dont affect the drive train (belt and rohloff) adversely.
I think "immediate" is the key word. I was a farm boy. I was taught early on not to lug down engines for longevity of the engine and drivetrain. From tractors, combines, to our trucks. I continue that practice on every piece of machinery I own. From my table saw to my eBikes.Can I full throttle the UC Titanium from a stop in high gear?
What will be the consequences?
I have done this on my Biktrix Ultra with no immediate consequences.
Thanks.
With my Biktrix Ultra, I have made an unanticipated stop without a chance to gear down first. The Biktrix has a chain and cogs, so you can't really gear down at a standstill; I have to be moving and pedalling to change gears.If you are using a throttle, please gear down. Regardless of IGH or cassette, having correct gear is essential for better longevity. (as @onlineaddy mentioned).
The throttle amps by themselves wont protect the drive train - it has to work with the right gear too. In our testing, use the throttle only up to gear 7 on the rohloff / kidnernay.
Rohloff has a gear display on the shifter.But is there a readout on the Watt Wagon to tell you what gear you are actually in so you don't do it by accident ?
Yes you shift a hub at standstill.With my Biktrix Ultra, I have made an unanticipated stop without a chance to gear down first. The Biktrix has a chain and cogs, so you can't really gear down at a standstill; I have to be moving and pedalling to change gears.
I am not familiar with rohloff / kidnernay. Is it possible to gear down at a standstill? Will I immediately damage the rohloff / kidnernay if I go full throttle at high gear from a standstill?
Kindernay doesn't display what gear you're in?Rohloff has a gear display on the shifter.
kindernay doesn’t, but is easier IMO. My “best” practice is to shift down two times (3 gears per shift x 2clicks=6 gears) after you stop. So let’s say you are in top gear (14), minus 2 full clicks = gear 8). That is within range of getting started with throttle.
No. It doesnt - it has thumb shifting so typically they dont have a "display"Kindernay doesn't display what gear you're in?
