Gionnirocket
- USA
- City
- Y. O.
I'm with youI used the 5 KT settings for PAS 1,3,5,7,and 9. For PAS 2, I split the difference between PAS 1(13) and PAS 3(20), using 16. Did the same for 4, 6, and 8, to maintain that curve the best I could.
Regarding his explanation for using 100 for a speed limit ("If you set a limit on spd, then each time you reach a particular speed, the motor would cut power. For example, if your top speed is set to 32kph, and if Assit1 spd% is set to 10, then if the bike reaches 3.2kph, then the motor would stop assisting in level 1. This is not desirable.")
I had to read that several times, but with the 100 settings, he's disabling the function where the motor stops assisting at a certain speed, which sounds logical to me, the way I'm reading it anyway. I'm not seeing that as something I need - but - it's early in my exploring here. There could be something subtle going on somewhere else that I'm not seeing yet.
As far as establishing lower "Limit Current" settings, to me, it's not about trying to get used to the OEM settings here. I rode the bike for 50 miles or so prior to hooking up the laptop - to get a clear picture of what was going on. For me, changing these "Limit Current" settings was necessary to actually provide some of the power required to move the bike myself. That's nearly impossible with the OEM settings. Bonus was the OEM settings just gobble up energy from the battery unnecessarily. These new settings are MUCH more conservative. Not just giving you a chance to contribute (rather than just ghost pedaling), but also extending the available range noticeably.
I will say that somebody riding a bike like this more aggressively, where the bike is seldom used in the lower PAS levels, or they are just using throttle alone, could probably care less about these settings - until they get tired of wiping the battery out in 15 miles or less anyway. My target is an easy 35 miles at least.
Will make a change to the "Pedal Assist" tab today. Going to turn down the "start current" now set at 30 to 10 or 12 and try that. This is another attempt at reducing wasted power without sacrificing much in the way of performance. Will see how that works... -Al
My comment on "getting use" to was referring more to the Pedal Assist /Start Degree setting. There's so many riding variables that it's hard to know how some settings will react until you live them.
I'm with you on the current settings as in my opinion both the stock and the increments of 10 that everyone hails as the holy grail are total crap.
Still not sure on the all PAS speed at 100 and I understand what he is saying. . just not sure I agree. I've already made the changes on my laptop and as soon as the afternoon sun warms things up a bit I'm off for a test drive.
Don't make this too interesting or I'll be looking for a bike with the Ultra!!!
