BBS*** Settings for a Smoother Ride
Same firmware.
If everything is working well and physically they appear to be BBSHD, I think you have nothing to worry about.
Bafang seems to change things at random and without reason or explanation so it's hard to keep up sometimes.
Now tweak your settings and go enjoy your rides!
I'm working on finding the right settings that will make the bike ride at slow speed around 15 kmph.
There are many different approaches.
Mine is this...
Set each PAS (Motor) Speed % to different cadences that you need and/or are comfortable maintaining and the corresponding current to just enough to do so. Your road speed will depend on which gear you are in.
I use my gears pretty much the same as before installing the motor.. though the motor does alow you to cheat up a gear or two.
