mschwett
- USA
You are not correct on this. Motors like to spin fast so the best way to provide the motor power to the rear wheel would be a small front cog and a larger rear cog. Check out the configuration of Luna's Sur-Ron electric cycle (very small front and large rear and single speed). This is pretty much how every electric motorcycle is configured. Sure mid-drives when in the lower gears (ie getting a mechanical boost from the gearing can climb well but there is a compromise taking place when you combine human and motor thru one drive system). Think about a rider putting their power thru that gearing you mention and they get a good boost at a desirable cadence but if the motor is separated a small front to a very large rear will significantly boost the motor torque more than sharing what is best for us weak pedaling humans. If you are riding a say 20mph with a 44T front chainring and an 11T rear chain ring on a mid-drive the combined human and motor torque is dropped 75% just to provide reasonable cadence for the rider. If the motor was on a separate drive the torque would still be magnified (there are other factors such as motor Kv and Kt that play into this but just given that motors are more efficient spinning fast I don't think there is much chance that integrating a motor and rider via a mid-drive is optimized. I don't think there is any technical merit to saying a combine drive system is best. Simple not true based on everything I know but I'm wanting to know if there is any chance this is wrong.
the solution is very simple though: you optimize the electric motor for the weight, size, and power targets of the bike/vehicle and that have internal gears to match it to a speed which is compatible with the human rider. it’s a bike. not a motorcycle. the efficiency of a derailleur drivetrain is incredibly high, and the latest IGH are getting there as well.
as you know, most all hub motors are also geared (again, size and weight, which is now rotating mass!) which further illustrates why the quest for an arbitrary 1:1 relationship between motor and axle speed is quixotic.
the bafang motor you’re talking about is also geared internally, to produce optimum power in the RPM range expected of the crank of a bicycle. if they had expected it to drive the rear axle at 1:1 at the “middle” of the range, they’d undoubtedly have geared it differently. for most bike drivetrains 1:1 is the extreme, with 1:2 in the middle and 1:4 at the other end.
