Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
Another price increase in Poland (as of today). Vado SL 4 non-equipped is 18,000 PLN now.
Check Trek's website. Not available on line but it seems a couple shops somewhat near me have decent availability of colors and sizes. I'd be interested in either a Medium or Large and both shops have several choices. If the numbering is following the regular FX line, FX2 is relatively low end. Will be interesting if they come out with carbon fiber and higher componentry versions of these later.If they sold these in the U.S. I would by one.
Almost sounds like the motor assiste is similar to riding my Specialized 4.0 SL in Turbo mode. Starts/accelerations give a less than smooth sensation compared to the lower assist levels.I have been for a couple of short rides on my wife’s Trek Fx+ and I think I am starting to understand more how it works. It seems the torque sensor controls the motor assist by on/off switching rather than varying the assist in proportion to the rider’s effort. In effect, the bike behaves more like one with just a cadence sensor, in that you only have to turn the pedals and apply gentle force in order to get relatively strong boost, based on the selected assist level (1-3).
There is a delay of about half a pedal rotation before the assist commences, and a delay of a second or two when you stop pedalling before the motor assist fades. The assist builds and fades fairly quickly but smoothly.
The overall conclusion is that the motor assist is not as natural as either the Specialised Vado SL or the Trek Verve+ 2. Nevertheless, my wife prefers the Fx+ over the Verve due to its lighter weight.
I am puzzled. All info I can find on the Cannondale Treadwell indicates it has the Mahle ebikemotion X35 drive.The new Treks are available in the U.S. now. My local Trek dealer should have received a small Dual Sport+ last week. I will likely go in to check it out this week if they haven’t already sold it. The price is very appealing, and the Hyena drive system has gotten decent reviews when used on other bike brands (e.g. the Cannondale Treadwell).
The only thing that I see as a knock on these models is the fully integrated battery. For commuting most people need to be able to remove the battery to keep it out of the elements for long periods of time because a lot of people don't work in an office building.The new Treks are available in the U.S. now. My local Trek dealer should have received a small Dual Sport+ last week. I will likely go in to check it out this week if they haven’t already sold it. The price is very appealing, and the Hyena drive system has gotten decent reviews when used on other bike brands (e.g. the Cannondale Treadwell).
There are a number of e-bikes with integrated battery, which has both pros and cons for various people. It could also be argued that an integrated battery is better protected from moisture, as the electrical connections are inside the frame rather than external. Obviously, there are other bikes to choose from if you decide a removable battery is best for you, but others may make an equally valid choice to favour the integrated battery. It’s great that so many options are available.The only thing that I see as a knock on these models is the fully integrated battery. For commuting most people need to be able to remove the battery to keep it out of the elements for long periods of time because a lot of people don't work in an office building.
I get it. If I didn't use the bike for commuting to work I would probably get one of these. Having the battery exposed to the heat and cold for 8 or more hours a day is my concern for the battery.There are a number of e-bikes with integrated battery, which has both pros and cons for various people. It could also be argued that an integrated battery is better protected from moisture, as the electrical connections are inside the frame rather than external. Obviously, there are other bikes to choose from if you decide a removable battery is best for you, but others may make an equally valid choice to favour the integrated battery. It’s great that so many options are available.
I like the bikes and the price is right too.
Not sure of the availability now - but Trek says a range extender with 250 Wh is an option. Presumably it is somewhat easily removable and could be charged indoors while at work. Also presumably if the range extender is fully charged while the internal is lower the bike will draw from range extender until the two batteries are equal in charge. Or there may be a setting that would allow using the range extender first. If this is the case and 250 Wh is good enough for you commute - the bike with range extender should work for your commute. Doesn't address your concern of leaving the internal battery along with the bike exposed to the elements.The only thing that I see as a knock on these models is the fully integrated battery. For commuting most people need to be able to remove the battery to keep it out of the elements for long periods of time because a lot of people don't work in an office building.
My bike is locked up outside for roughly 10 hours a day and I know if it had an internal battery it would be damaged in the summer on those 100 degree days.unless you park your bike in seriously unfavorable conditions, i wouldn’t be too worried about this. are you thinking sub-zero or 100+ temps?
Wow, that looks like a wonderful change.We visited our local Trek dealer today, and they were able to tune the boost parameters on my wife’s Fx+ using a Hyena Windows app and special Bluetooth dongle. They reduced the Level 1 boost from 12% to 5% which should make the bike more controllable for low speed manoeuvring, and this was verified by a test ride in the carpark. The numbers don’t quite make sense as 12% seems low to start with, assuming it refers to 12% of the maximum 250 W motor boost. The effect of the change on regular riding won’t be known until we do a longer ride, weather permitting. The change can easily be reversed or further amended if need be.
See https://www.hyena-ebike.com/hyena-service-tool/
