CurrieTech
They may be mistaking the 2013 or '14 Zuma battery with this Dash one. The Peak also has the same as the Dash, but with different decals.
why do you say definitely need a second battery? what kind of range are you getting?
I have a question, how many miles have you racked up on you're dash? What sort of maintenance do you do to the bike and how often? Have you noticed any slowing down of the motor or loss in performance, also thank you for such a great detailed answer as to the range. IT IS HARD TO GET A STRAIGHT ANSWER TO THAT QUESTION YOU'RE RESPONSE WAS VERY HELPFUL. THANKS.Kyle,
I live in Las Vegas…all my rides are on streets or sidewalks. The milage is really determind by how much power you need or want. I ride in PAS 1 or 2…if i need more power for a hill i just use the throttle. I have done lots of test on my bike and one of them i only put it in PAS 1 and went 13 miles before one bar was gone and around 8-9 miles when on PAS 2. You can go an ez 40 miles on the dash but not if you want to throttle the whole way. The test in PAS 1 i went 27 miles before the 2nd bar was gone. I was done for the day after that but i believe i could have gone over 60 miles at that pace. So one battery should be fine, but if you are one that just wants to use the T then maybe a 2nd bat is a good idea. But if they came out with a bat for the dash with longer AH i would be interested too just for peace of mind. hope this helps….if you have more questions plz ask…I have had my dash since Feb 2014.
Justin
Could you explain what happened to cause the creaking noise? Can it be fixed by tightening all the bolts screws and maybe oiling the suspension and chain? And as far as the motor getting more noisier would you say it is really bad? Also how long would you guess that the dashes motor would last? 5000, 10000 miles? Based on your own use so far. Thanks for the great response to my questions earlier!Follow-up from my earlier post re: the Dash.
On April 22nd I bought my Dash and was excited about biking to work and dropping my boy off at day care while I went. It took about two weeks to get everything else I needed equipment wise. The major piece was a rack that would mount with disc brakes and that held a child seat. Debated about using a trailer, and in spite of what every child safety advocate in the world states, finally decided that it was safer to not use one to ride on a mix of city streets, neighborhood roads, sidewalks, paved bicycle paths, and improved dirt paths. Finally, I was all ready to go, and one morning I realized that the morning temperature in Denver was still below freezing in late April/early May! Three days later I got two days to commute, but my brake cables had stretched so much since I bought it that I had to bring it in for its warranty service. One week later I finally got the bike back, but then three more mornings of unseasonal cold. Then finally last week thursday the morning temp was finally above 40 degrees. Bundled the boy up in his winter coat, his gaiter, and helmet and off we went! I have commuted these last three working days, and I love it!
I'm making my 13 mile trip to work in about 40 mins in the mornings. So I'm averaging just shy of 20 MPH. I have a few route changes I need to consider to boost my average speed. I thought that bike paths would be great, but some of them are a little too meandering and frankly not safe for me to fly down at 25+ MPH (which the Dash does w/o any real effort), plus some of the hair pin turns are a little much.
26 miles round trip, and I have to charge at work, which is a story unto itself considering the field I work in, but the 2 year old loves his rides to day care.
Then today I had a bit of scare, the battery ran out before I got home. It was a mixture of factors, one being I leave the bike in PA4 all the time (totally unnecessary), it was hotter today, about 85 degrees, and finally I was riding the bike very hard in high gear, which was probably causing the torque and cadence sensors to apply more power than was necessary. Then I got home plugged it in and the battery charger started flashing red. Panic!!!
Read the manual and it said to let the battery and charger cool down as my first step (actually it was the last step in the manual, but it was logically the first step). So I stuck it in the fridge and 30 minutes later plugged it in and now it's charging.
Just hit 200 total miles on the bike today as well, and I figure I'll put on ~600 miles a month. Aside from all of my little problems which are mostly just dealer assembly issues, excessive heat, and sheer laziness on my part I am very happy with my purchase so far. There's a few creaky sounds that are coming from the bike, but that always seems to happen when I bring any bike in for service. Another thing is that the motor seems to be making more noise than when I first bought it, and there seems to be a bit of jerkiness in when the motor assists kick in and out even when I'm under 28 MPH. I'm going to keep paying attention to these potential issues.
And yes when I get to work I need to change and wash up because I did just get a work out. I feel better than I have in months, this is just what I needed.
Dash = Pure Fun and only adds 20 total minutes round trip to my daily commute.
I just looked and have 348 miles. I don't use ride my bike everyday its more of a lifestyle. Take it to the gym, parks, san diego, parker AZ, just to be outside, my wife has the 2013 metro so we go to lunch and just cruise. I have and do sometimes take it to work (24 miles round trip) on nice days and when i do……DASH to work! I have had it going 32 mph with ease.I have a question, how many miles have you racked up on you're dash? What sort of maintenance do you do to the bike and how often? Have you noticed any slowing down of the motor or loss in performance, also thank you for such a great detailed answer as to the range. IT IS HARD TO GET A STRAIGHT ANSWER TO THAT QUESTION YOU'RE RESPONSE WAS VERY HELPFUL. THANKS.
Just shy of 1000 miles on my Dash. Needed to replace all the brake pads (lots of stop and go in the city) and replace the front brake cable. Other than that, after my initial issues the bike has been solid. The brakes do need constant adjustment due to my riding style.
No loss of power. Motor is still silent, low 30's on a flat. Battery still holds a decent charge after 200+ charge cycles.
Next year I'll look into getting a 2nd battery. (Or find a 4amp charger)
And...after 200 miles, looks like my cadence sensor took a poop. (E4 error)
