Ralph
Hi Ralph - No slime tubes on the Dash. Generally, we only use Slime when we have bolt-on, nutted hub motors that are difficult to remove for flat repair. Slime works well for small punctures but makes a real mess with something larger. We have had lots of complaints about the use of sealers. The good news is that the Dash (and also the new Path+ which uses the same motor) has a standard quick release rear wheel and an easy connect power connector which makes removing the rear wheel almost as easy as on a normal bike, so its pretty simple to replace the tube if you do get a puncture.
The tires are also very tough if they are kept properly inflated. This is something that many riders neglect to check on a regular basis. I'd suggest getting a good floor pump with a gauge and top off your tires once a week before you ride. Follow this and carry a spare tube, tire levers and a CO2 inflation cartridge when you ride and you will be amazed at how infrequent flats become.
Hope that is helpful!
Larry
Larry, Thanks. Your comments are a big help. I will scrap the idea of sealants and take your advice. Currently, we check the air in our tires before every ride on our regular bikes. I will assemble a tire kit as you suggest. I appreciate your help.
Ralph
