I've heard good things about the Kool Stop pads, but I am fresh off the boat here.
In other news, the first bike arrived yesterday, and it looks like a good, sturdy bit of gear. The "Super Stealth Dark" is a decent looking metallic gray. The 17.5" frame seems to fit correctly, if slightly high, with the 29" wheels, so I think when I get the 27.5"s installed it should be right on. Need to get on Bikesdirect to send me the specs on the rims, as I need to order my spokes and IGH for the rear wheel rebuild.
I did have one issue out of the box: when I flipped the bike over and put the front wheel into the fork I found that the disk rubs on the left (outside) brake pad. It doesn't rub and skip off. Just consistently a millimeter or so too far outboard. I tried loosening the caliper, closing the pads on the disk, and then retightening, but that didn't seem to help. Loosened it again and retightened while applying a little pressure to the caliper to push it slightly toward the midline, but again, no result. I don't think the disc is bent, as it scrapes along very consistently. Any ideas?
