Whatever floats yer boat!Thanks Thomas,
Yeah. Getting the hearing right would be critical for a single-soeed. But whyspend extra for a mid-drive and not take advantage of the possibility of a low and high gear option, amirite? I think a 42-44T up front and an 18 out back should make for a nice all-around street/trail range. If my Nexus-4 were disc rather than just a freewheel I'd have tried that, as it's 1:1 in first gear. Speeeeeeed!
Good call, there have been discussions on this forum about the Sturmey 5 failing on the Luna Babe, at least one ebike designer on this site @pushkar changed his mind after replicating the fault and specced the Shimano Nexus Inter-5E on his upcoming WattWagons model.As excited as I was to use the Sturmey 5-speed IGH, more research last night reveals that nothing beats a 3-speed for durability in the IGH world (Sheldon Brown needs a hobby!)
Buddy has an 8-speed Nexus from Electra, a Townie from the frame built in WI years. Rim failed and was rebuilt and the Nexus still rocks on! These days it doesn't see heavy use but still impressive! No goofy Gearsensor either.Good call, there have been discussions on this forum about the Sturmey 5 failing on the Luna Babe, at least one ebike designer on this site @pushkar changed his mind after replicating the fault and specced the Shimano Nexus Inter-5E on his upcoming WattWagons model.
LighteningRod? Beats the crap out of Cyclone (mediocre design by comparison) Unfortunately the LighteningRod is more spendy but made in USA and very well supported.Oh, and Ive already started dreaming of a future build mating a LightningBolt or Cyclone and an old Nuvinci N171 CVT!
Yes I use a Nexus 8 for my BBS01 I bought from Doug because I wanted the lower gear range for pedalling up hills. I think the Nexus Inter-5E would work fine for a more powerful motor that doesn’t need lower gears - on that model 1st gear is the 1:1 ratio so no granny gears, no problem if the motor can handle itBuddy has an 8-speed Nexus from Electra, a Townie from the frame built in WI years. Rim failed and was rebuilt and the Nexus still rocks on! These days it doesn't see heavy use but still impressive! No goofy Gearsensor either.
You, Sam, and I must be the last BBS01 users two 350W 36V, and 2 36V 250W here. Our path bikes.Yes I use a Nexus 8 for my BBS01 I bought from Doug because I wanted the lower gear range for pedalling up hills. I think the Nexus Inter-5E would work fine for a more powerful motor that doesn’t need lower gears - on that model 1st gear is the 1:1 ratio so no granny gears, no problem if the motor can handle it
A little-used 4-year-old Luna 52V triangle 20AH (maybe PF cells) still has very little sag and rocks at 28MPH for the first 20% of voltage, and 25-26 until LVC.
How do we hide 60-100 cells? It is what it is. I like EM3ev batteries. I have 6 year old batts from them still putting out decent amps. And the new builds have Bluetooth BMS that can be monitored with a smart phone. Full disclosure we sell them but I have a long positive history with them.Don't get me started on batteries. Like, really don't. Honestly that's the part of this whole build I'm most dreading. Why are they all so... visible? Clunky? Insecure and subject to theft/vandalism? Eager to explode if insulted or abused? Why can't I just stuff the entire frame with lithium and ions and crap and be done with it?
iPhones work too.Their 52v Super Shark looks nice and compact. Sadly, I have no Android device. Do I still not need a controller?
I have no idea what a Super 73 bike is. EggRider is not for someone not able to sort through the setup and some computer skills. eggrider.com has a manual. Best to review that before plunging. They are also active on Facebook. Typically a new rider should start with a simple display. IMNSHOIs the Eggrider display the one used on the Super 73 bikes? Love the idea of programming presets that I can change on the fly!
You'd need a custom enclosure for a triangle. I use triangle nylon bags but live in a pretty low crime city.Is there a way to secure a triangle battery such that a mildly interested tween couldn't make off with it in under15 minutes? Somehow those fish themed batteries make every bike look like something to cruise around the retirement village on, not that there's anything wrong with that.
Thanks Tim. I only consider the 1000w BBSHD, as I've heard that the BBS02 has issues with a nylon gear. I'd likely leave in in class 1/2, and unleash it on a future build with better anchors.
Hmmm... the plot thickens! A new contender! Is 5th gear direct? To the Interwebs!
ETA: was hoping to avoid a centerlock disc. Should I not?
I looked on bikeforums.net and couldn't find any complaintsI just vaguely recall reading somewhere that center locks were less desirable in some way. Maybe less compatible? The Betamax of discs? If they're fine, I'm fine. Thanks!
All from a single source repeated ad nauseam. There were rotor issues but now corrected.I know nothing I didn't read on the Internet, but a quick google of 'BBSHD peanut butter' turns up a lot of results.
I also am getting a kit and using rim brakes on an old Trek...what would you consider a "good" pad to use vs disk brakes?Disc brakes are definitely preferred but are not the end all and be all. I’ve had a couple of ebikes with rim brakes, and I had one with cheap disc brakes. They were all problematical. You can do OK with rim brakes if you put on really good pads. I’d rather have rim brakes with good pads than cheap disk brakes. High quality disk brakes are the best, but you can make rim brakes work.
