Greetings and Salutations!
So I've recently begun obsessing over e-bikes after selling off the 2008 Ninja 250 that was my daily driver for several years. My thinking is that I could use it for my short work commute during the summer, and let my 12-year-old ride it to school if that ever happens again during the school year. There are, of course, lots of decent and reasonably priced bikes available lately. The Civibikes Cheetah is beautiful, and I'm intrigued by the Super 73 minibike style rides, as well as the Luna fixie and BABE, but that's just by way of introduction. I've had bikes apart before, and used to wrench on my Honda XR75 back in the day, so I'm comfortable enough around bikes and tools, although I've never removed a bottom bracket. How hard can that be?
In my shed I have a lightly used, 2002 Trek Clyde: https://www.bikepedia.com/QuickBike/BikeSpecs.aspx?item=37639. It's a aluminium framed retro-cruiser with a Shimano Nexus 4-speed IGH, ProMax V brakes, and not much else. Tires are 26 x 2. Considering that the least expensive e-bike on my radar is around $1700, which would only get me a hub motor and mechanical disk brakes, a 750 or 1000W mid-drive conversion kit @ $800 - $1000 seems like a reasonable avenue to consider. It would give me the flexibility to build something else later on, and take advantage of the existing IGH for now, as I enter the e-bike world.
So right off the bat, and armed with an Internet education, I've got some worries:
1) The Shimano Nexus 4-speed IGH was discontinued in 2005, apparently over reliability issues. Here's the specs: https://www.sheldonbrown.com/nexus4.html
2) The 2nd top tube and curved down tube limit my options for battery placement. I don't want a rack-mount battery.
3) The curved down tube will make mounting a mid-motor a bit challenging, as it continues forward from the bottom bracket before curving upwards. I'm guessing this will require rotating the motor so that the bit that normally extends forward from the bottom bracket is rotated downwards a bit. Probably not a clearance issue.
4) The existing V-brakes are likely barely sufficient at best. I've read that some retain the V-brake on the rear, and install a hydraulic disk up front, which I guess is an option, but hits the budget a good whack.
So... Am I buying trouble? On the right track? Living in a fantasy utopia of my own imagining?
TIA
TIA
