Following up on my past couple of posts in this thread (January and March -- I'm working slowly), I've finally gotten around to assembling a crack squad of componentry to bring this 3x3 Nine cargo bike to life.
I'll save all that noise for its own thread, once my build is complete, though that's going to be at least another month out. I am still collecting parts from all four corners and then some, and a couple are stragglers.
But I did finish up on the Rohloff torque arm conversion, which is what I posted about in this thread 9 months ago, and with the 3x3 hub in hand, I made a few slight modifications to get it properly fitted to the frame:
* redrilled the hole in the axle plate to get better alignment for the cables entering the shift box
* ground down the hub end of the Rohloff torque arm for clearance
* found a thicker P-clamp that's the same gauge steel Rohloff uses for their torque arm clamps
* switched the black bolts to "shoulder bolts" which have a non-threaded shank for better shear resistance
The point of me sharing this post & photos isn't so much a how to, but just for some inspiration of adaptation. I'm not sure how I would have / could have gone about this had this not worked out so cleanly, but I realize this is all very specific to the Yuba Mondo and probably can't be replicated in whole on just any other frame. This was necessary primarily because the frame has a non-standard disc tab placement. It was fortunate that VPL was willing to work with me and get me some prototype parts to play with before I committed to ordering the hub.
Oh, and just a note, the major reason for the delay was that my beloved outgoing analog cargo bike kept getting used all summer, and plus I was really hesitant to sell it -- I put a lot into that bike and created many memories. I should have just added a front hub motor to it and called it a day. By comparison, this Yuba just isn't an inspiring bike. The old cargo bike took up a lot of space in the garage, and I committed to not start this build until that bike was gone. I finally found a buyer last month, allowing this build to commence.
View attachment 216297View attachment 216301View attachment 216299View attachment 216302View attachment 216304View attachment 216303View attachment 216306View attachment 216308View attachment 216307View attachment 216298
