I finally took my ebike for a test ride.
My rings arrived,..
I need longer ring bolts.
I never used anything but the stock 46t chainring and guard... So I guess search Amazon and Ali.
Seems there's a bit more available since I retired my BBS 3 years ago
This is my stock 46t setup and gaurd, and lots of pictures to piss everyone off and use up their bandwidth. 😁
I woulda thought less?
The BBS02B UART is a 🦕 🦖 🐲
More wasteful pics 📸 📷
Even more wasted bandwidth,..
And more,..
And one more,..
From silicone grease.. to Slickoleum.. to posting pics.... The notion that less can be more eludes you 🙃
I fixed my mid-drive throttle too.
Now it stays where I put it,..
I added a stiction wire.
@PedalUma knows a guy that disappeared without a trace after he wrapped a zip tie around his throttle.
Now I can disappear twice as good, so's no one will finds me. 😁
I bought a four dollar throttle lock, but I prefer my wire.
Checking my thread depth,..
Thread just starts to grab,..
Threaded until it snugs up,..
Eight threads start to finish,..
Less than 2½ threads on the original hex bolts,..
Time to find new bolts.
About half a dozen threads longer?
In the interest of going Really Really FAST, I'm gunna remove my 42t chain wheel for now and go with the 52t until I gets new bolts.
I should be fine if I stay outta granny gear.
My derailleur can't stretch that far without a longer chain.
Ohh, FFS,..
I broke one of the damn mounting tabs off the chain gaurd,..
I'm really not keen on the cheesy plastic chain guard.
My original chain guard was a double sided bash guard.
I'm gunna see what I can find on Aliexpress.
Meanwhile, I'm gunna hot glue the damn tab back on.
I got the 52t chainring and chain gaurd installed.
The glued tab is holding.
So maybe with the big chain ring, and my 20 mph speed limit, I shouldn't need to use my 11t sprocket?
I might be able to use 4th or 5th gear to get 80% motor rpms?
I haven't done any gear feet tachometer calculations.
I'm just gunna wring the snot outta it and see what happens. 😁
Without speeding of course.
It seems to me that a rear direct drive hub motor would give you everything you want, and weigh less too.
Direct-drive motors and less weight! Maybe a first.
Yeah, there was no good reason to add the mid-drive. 😁
I don't even have any hills to climb.
I just wanted to do it.
It's kinda fun.
I could replace the rear hub motor with a regular wheel and just use the mid-drive?
Are you saying I should have replaced my geared hub motor with a direct drive hub motor instead of installing the mid-drive ??
That's no fun !!
Yes, for the riding you do.
You ain't lived until you have experienced a bidirectional throttle.
I've thought about regen, but the roads are completely flat around here, and I rarely use my brakes.
I can ride up to ½ hour straight without touching the brakes or handlebars.
Even the Grin guy says the best you can hope for is about a 10% return.
I've thought about welding my clutch, but adding a mid-drive is more funner. 😁
