Performance Report: Installed a Rohloff IGH on my Luna Z1 Bafang Ultra Mag in April 2023
Tom@WashDC
Loudoun County, VA.
I installed a Rohloff Speedhub 14 IGH on my Luna Z1 mid drive Bafang Ultra Mag back in April 2023.
Here is my installation thread:
  • Ridden it 4,000 miles, 70% off-road, aggressively.
  • I removed my throttle, and I ride torque sensing only.
  • I have had zero problems with the hub.
  • It performs beyond my wildest expectations.
  • Shifts perfectly every time.
  • I've never had to adjust the shifting mechanism.
  • Shifts faster and more reliably than a cog system.
  • Minimal maintenance:
    • I've chaged the oil three times
    • Replaced the chain once.
I could never go back to the old cog system.
Glad to hear your’s is still rolling strong.
You might not remember but a buddy of mine went that way after using your thread as a bit of a guide.
He blew his up and now has a 3x3 nine 9spd hub.
Evidently it has a higher torque rating than the Rohloff.
Get this… He originally had the 2300w version motor he got from WW and even though he rode 100% of the time in the lower max settings ( up to 1000w ) and not the higher range he was gun shy about using his new hub with the same motor.
So…. I had a spare back up bare bones motor, 1000w version that he bought from me AND had me tune down the software to 21a max and lower ALL the relevant settings so as not to stress this new one out.
Then he complains about about it being gutless.
So… I had to tune it up for him to a higher level to satisfy him.
We’ve been riding every Tuesday Am for 3-4 yrs or so and he’s still all about using his throttle and typically runs in level 4 for the most part.
Been riding my Levo for about 6 mos and I can still drop him, except on long climbs where he can power up and go faster than I can.
I’ll be sure and tell him your hub is still going strong.
Sorry to hear that he busted the hub. One thing I have done is eliminate my throttle. I never used it while riding, the torque sensing really works well for me. I've been running the full 30A on my Ultra with no problems. Out of curiosity, do you remember how many teeth he was running on the front and rear sprockets. I'be got mine sized at 50T front, 16T rear, which keeps me well within the Rohloff tourque guidleines.
Question, if he overtorqued his hub, the sheer pins should have given way preventing any damage to the hub and they cost about $10. What actually happend to his hub?
Pretty sure he was running a 16t cog on the rear and probably a 50t chainring as well.
The issue with his was getting intermittent shifting or slipping on his middle gear range.
Not necessarily under heavy load but just riding on the flats so we replaced some springs which did nothing.
He recently just sent it back east somewhere to NY I think to have it serviced and He’s got another bike he is going to put it on as he’s all in with the 3x3 nine hub.
Time will tell.
Glad your doing well.
Time will tell.
Gotcha. Thanks for the info
Time will tell.
Not sure if it's really an issue. . .
On the flip... I'm lovin' the Rohloff too.
Can't say that I'm a power rider but I do take it off road and with the Ultra... that bitch can climb.
44t/16th so a little closer to the Rohloff lowest gear ratio of 2.5:1
28A max global current but I'm mostly under 10a throughout a majority of the ride. I do spike and sometimes sustain over 20a on long hill climbs.
ymmv
ymmv
I cannot believe how sweet it is when paired with the ever powerful Ultra. A total pleasure to ride, glad you are digging yours as well.
I cannot believe how sweet it is whenpaired with the ever powerful Ultra. A total pleasure to ride, glad you are digging yours as well.
Finally got all the bugs and installation hacks squared away on the bike.
But even when just received and not as it should have been.. It was still better than a derailleur!
Update since my last update January 2024: Original install April 2023.
  • I ride 50% off road MTB trails, 50% paved trails
  • Zero problems with the hub.
  • Shifts perfectly every time. I've never had to adjust the shifting mechanism since day one.
    • I change the oil 3X per year
This is good to know. My next project is to remove the Speedhub from my analog cargo bike and pair it with a 500W Shimano EP8 CRG motor on a Yuba Mundo frame. A mechanic from Omnium warned me this was going to blow up the hub if I don't use electronic shifting, which left me shaking my head. If I can make a Speedhub last on a mountain tandem (talk about abusive shifting!), I think I'm good to go.
I see from your original post that your hub came with the flange support rings already installed. Do you remember if that was an option or were you even aware of them? Those were recommended retrofits for tandems and cargo applications going back to the 2010 timeframe.
It's been 3 years since I installed the Rohloff Speedhub14 on my Luna Z1.
Original Installation post: Rohloff Install
  • Not a single problem.
  • I've never had to adjust the shift mechanism in three years.
  • Perfect shifting every time.
That is all.
That is all.
Wow lots of good info in that build thread @Tom@WashDC – thanks for linking to it.
I had intended to go a similar route being a long time Speedhub user. I reached out to a few bike shops who should have been able to provide assistance with the measurement for the A14 measurements and didn't get satisfactory replies., combined with the current state of the import market, I chose to go a different direction.
I went with a 3x3 NINE hub for my Yuba Mundo and we'll hopefully be getting to it soon. Much is your installation as it allows for an actual through axle, though there are still some fit complications with the process due to Yuba's deviation from standards.
In the meantime, I've got a collection of Speedhubs in the fleet including a mountain tandem and cargo bike (all non electric) and have never had a failure or any mechanical trouble with them.
