Just a thank-you to everyone who helped me with my planned SL 1 brake upgrade. Going with Shimano GRX RX820 gravel calipers and 1-finger levers. Will probably have all necessary parts by the end of the month.
Fascinated to hear the outcome of this. That sounds like it should be a night and day upgrade.
What levers did you choose by the way?
I certainly hope so. Will report back.
Shimano Deore BR-M6100 Front lever $30
Shimano Deore BR-M6100 Rear lever $30
Shimano GRX RX820 Front caliper $100
Shimano GRX RX820 Rear caliper $100
Shimano 160 rear caliper adapter $21
Shimano BH-90 hose kit $33 each ($66)
RT64 160mm rotors $40 each ($80)
Front labor is $100
Rear labor is $ 120+
Total $657+ before tax
Part prices are in line with those on Jenson USA. The listed levers and hoses were originally proposed for the RX410 calipers — no mention of changes needed for the RX820s. The rear labor figure assumes that hose routing around the motor goes smoothly.
Fingers crossed!
Front labor is $100
Fingers crossed!
What's that rear adapter for Jeremy? Is it a post mount caliper or something?
It's crazy to note that if you went for the GRX 820 Brifter lever you'd be paying $300+ for one! They f*ck you at the (drop bar) drive in!
Front labor is $100
Fingers crossed!
As long as the lever and caliper use the same type of mineral oil (standard or LV), they are compatible.
The calipers are flat mount. The adapter is for 160mm rotors. Direct mount is 140mm.
Front labor is $100
Fingers crossed!
As I understand it, your levers are not much different to my 8100 XT levers - you will love the one finger operation I am sure.
The overall feel and modulation of that full setup should be really impressive.
The Rear Wheel Matter Becomes Hot!
I also asked for an advice at a gravel cycling group. The same man who convinced me the Wheeltop derailleur was a good thing also convinced me to contact a wheel builder by name Lemon Bike. So I got an offer:
  • DT Swiss U623 rim (29", e-MTB, 25 mm internal rim width, total system weight limit 180 kg, 32 spoke holes), RDU623CDAB32SA9807
  • DT Swiss 350 Classic rear hub, 12x148 mm, 32 spoke flanges, Centerlock, Star Ratchet 24T, steel freehub (HG freehub), H350TCDSR32SA9853S
  • Sapim Strong spokes with Sapim Polyax Double Square nipples, 32 pcs.
That should be a super strong wheel! The price is by a margin higher than the HU 1900 ready wheel I considered earlier.
I will ask for the shipment for after 16th April when I'm back home.
My Creo 1 has wheels built with a gravel 32H G540 rim and 350 hub with over 15000 miles. They are still as true as when they were new. My Creo came with oem Roval carbon wheels but I exceed their load rating so I never used them and sold to pay for the new wheels. Not worrying about wheels is good especially bombing down hills.
My generic Specialized rear wheel on Vado SL had survived 20,130 km (12,500 miles) before I decided to replace it. The U623/DT350/32 Sapim Strong combination is rated for such a high load I wouldn't hesitate installing in on my heavy Vado 6.0, especially with the rim width of 25 mm (which would allow me using 47 mm tyres). I should receive the shipment in two days, excited!
And well, my riding style for Vado SL has changed. No more grocery or overloaded rides for that e-bike! (Riding rough trails fast will be OK).
@Allan47.7339: Is your rear hub 12x148 mm, Centerlock? No issues to install? Alloy or steel freehub body?
Back in December I asked for tire recommendations for my SL 5.0. I'm finally getting around to ordering some fresh rubber after going on some great rides over the past few months. I'm looking for the widest tubeless tire I can squeeze onto my bike. I'm used to mountain bike tires inflated to 25-ish psi, so the stock 38mm Pathfinder Sport tube tires feel both very hard (inflated to around 50-55 psi) and a bit narrrow/skittish on gravel descents. I didn't have much confidence in those environments.
I'm not running any fenders, nor do I plan to do so, and I have decided to go with the Specialized Pathfinder TLR (the tire that replaced the Pathfinder Pro). I'm confident the 700x40 will fit no problem, but has anyone tried the 700x45? One of the reviews I saw at this link noted that these tires run a bit narrow. The owner wrote, "Can't comment on performance yet, but I can confirm that the new Pathfinders seem to run a little narrow. The new 45mm tire measures 43mm installed on my 25mm internal width rim." I'm wondering whether to gamble on the wider 45 width. I believe the stock DT Swiss R500 wheels on my Vado SL 5.0 have a 22mm internal width, which means that when installed, the tires would measure even narrower than what the above reviewer observed on his bike with 25mm internal widths, correct? Any thoughts or comments? I figured some of you have probably already tried installing tires that measure 43mm wide. Thanks so much again for any input...really appreciate the guidance!
Yes the Creo 1 is road boost with 12 x 148mm Centerlock. It came with Shimano but I have since converted to SRAM with a XD driver. Centerlock is not required as you can also use a six bolt sensor although some third party magnets may not work. See the All About Turbo section article:
Here It Is!
  • DT Swiss U623 rim, 25-622
  • DT Swiss 350 rear hub, 12x148 mm, Centerlock (new model: Hybrid)
  • Steel HG freehub body
  • 32 Sapim Strong 290 mm spokes
  • Brass nipples
  • Tubeless tape
  • Presta valve adapter
  • Maximum system weight 180 kg
  • ASME classification: 2 (gravel)
I armed the wheel with
  • A custom 11-speed, 11-51T cassette, custom, based on CS-M5100 (gears 1-6) and CS-M8000 (gears 7-11)
  • A 160 mm Tektro brake rotor, Specialized e-bike magnet bracket.
Than I completed the wheel with a Specialized Rhombus Pro 42-622 tyre and an inner tube.
As I was installing the wheel back on my Fearless, I had a little panic attack :) but all went well. Setting off for a test ride soon.
Dismantling the cassette was a good thing. It was not only full of grime but I could also remove some twig that was entangled in the cassette from the back! Moving the magnet holder was an opportunity to clean the magnet, which was extremely dirty as well :)
Ooh, let it work... I'm setting off for a 100 km gravel group ride I've organized tomorrow!
I put some Hunt carbon wheels on my SL2 recently. Despite the 700g reduction in weight (per wheel) I can’t say I’ve felt much difference in performance Other than the bike being easier to accelerate from standstill. They are rates as being suited to road and light gravel so not for the rides you do Stefan! At £500 and weighing just 1400g they were well priced.
Yes per set. Increased price to £566 now as they had an extra 10% deal on top of the 33%. Seem to get good reviews…….time will tell.
An excellent price as for carbon wheels from a well known brand! Regarding my Lemon Bike wheels, the builder company offers them to e-bikers and bike-packers. Comparing the weight per a wheelset: yours 1400 g, mine 2360. The U623 set can be bought for an equivalent of 410 quids. I simply didn't need the front wheel and had some custom requirements (like, a steel freehub body as the alloy ones by DT tend to errode).
Interesting observation very much in line with what I've been reading lately about the real cost/benefit of weight reduction in cycling. (Several recent GCN videos on this very topic.)
Sounds like you might feel the acceleration and overall responsiveness benefit with, say, a 1 kg reduction. Maybe also in manhandling the bike and on steep climbs.
One thing's clear: Wheel mass is the most effective place to start cutting but not necessarily the cheapest. And for riders with no compelling need for the main benefits above, the return on investment seems pretty dubious.
Ran the numbers on my own SL 1 at 105 kg system mass. If the system were to magically lose 10 kg (9.5% of system mass), I'd save only 4W on the flat at a steady 24 km/h (15 mph), and only 18W on either a 5% climb at 12 km/h (7.5 mph) or an 8% climb at 8 km/h (5 mph).
So in theory, not much incentive to pay $$$ to lose 1.4 kg in wheels for my usual climbing. But I'd still consider it for the potential gain in responsiveness in ECO and OFF.
One thing's clear: Wheel mass is the most effective place to start cutting but not necessarily the cheapest. And for riders with no compelling need for the benefits above, the return on investment seems pretty dubious.
Well designed carbon wheels are stronger (relatively) and ride better (subjectively) than equivalent aluminum wheels. They are also more aero, so put that into your calculations. I've been riding carbon wheels for so long now, I won't go back. The aluminum wheels that came with the Pinarello lasted one ride before I knew that I wanted to swap them out. High quality carbon wheels just ride better.
