It depends.
Steep downhill:
Yesterday, riding my Creo down a short, but steep, gravel road (range of 6% - 23%) with ruts...first time riding that trail, I had my dropper down, gripping the drops, and standing on pedals... Initially I slow with light rear braking, to see the looseness of the Category 3 gravel/dirt. then lighten up the rear a bit and add front brake to control my speed (max 12mph) to navigate the ruts crossing the trail. some of the loosest steep stuff I've ridden on the Creo so far. Then I modulated front and rear, as needed.
Mild downhill: Usually I tap the rear brake first, then add the front, modulating it as needed.
Flat: First light rear braking, then finish with the the front brake.
Here is that steep loose section (thanks to Garmin + Strava):
I was paying extra attention on the loose gravel, since I slid out on loose dirt, over hardpack dirt on a downhill off-camber turn, riding my MTB, two days prior.
