Rear Wheel Removal Tip
Looks like I have my answer as I am using tube tires
Muc-Off and FlatOut are different products used for different purposes:
Muc-Off is a brand of tubeless tire sealant, while FlatOut is a brand of tire sealant additive that can be used in a wide range of tires, including bicycles and cars. Muc-Off sealant is designed to be injected into a tubeless tire to seal punctures up to 6mm, whereas FlatOut is a fiber and filler-based sealant designed to last the life of the tire by forming a permanent plug at the puncture site. “
Also, knew there is nothing harmed by turning bike upside down.
I found the easiest way to invert my e-bike was to lay it down, then walk around to the other side, grab the wheels and "roll" it up onto the seat and handlebars.
I just had to watch that nothing got crunched while "rolling" it over.
A strap or bungee cord around the wheel and top tube really helps to get it upside-down without falling over.
I noticed too that my e-bikes are really light on the front end when upside-down, and the handlebar stands lift off the ground when I removed the front wheel.
I've "crashed" my ebikes more than two dozen times, (fell over) including three times inside the house.
I almost broke my TV when my e-bike fell into it. 😁
Well that's good news.
I bought the right stuff then.
I've got innertubes.
I did know that Flat-Out doesn't dry out. Most of the other sealants dry out and need more added regularly.
I like the Flat-Out, set it and forget it, just like my waxed chain.
Flat Out has Kevlar in it :)
Flat Out say’s works for both Tube and Tubeless Tires
Maybe, if possible, you can take an unpowered ride on your ebike before you change your tires to get an idea of how hard you have to pedal with your nobby tires, then do it again after the tire change.
That will give you a idea of how hard the motor and battery has to work just to get going.
Then set your tires to the lowest recommended pressure (it should be printed on the tire) and pedal it around some more.
I'm guessing that you should easily feel the difference in effort between the tires, and it will show you how much energy is wasted just rotating nobby tires, especially fat nobby tires inflated to 6-8 psi.
I like tangible results that can be felt.
I can't feel any difference with my waxed chain, but it is smooth and quiet. 😁
I have already done that when I first got it before the battery was charged up. Mind you 10 lbs less Our area is hilly. Going down hill checked gears out and it was great until I turned around to go back up hill and I had to get off and walk it back. It is 74lbs without the battery and without me. Now consider someone who hasn‘t been out riding since back surgery, lost leg strength trying to pedal uphill a 74 lbs bike with 4” tires. Not working!
I've only pedaled my e-bike once when I ran out of battery.
It was my first trip with two batteries and I wanted to see how far I could get on one battery.
When my first battery was depleted, I went swap batteries and realized that I forgot the key to remove the battery.
It was a PITA to pedal it, but fortunately I was only 5 miles from home, I've got no hills to deal with, and I've got a Super Low granny gear so I could pedal just fast enough to keep my balance and pedal home at 2 or 3 mph.
I was lucky because I was planning on draining both batteries with a ~100 km trip, but changed my mind and decided to just kill one battery, so I was close to home when the first battery died.
Sometimes when you drop a small part they can bounce and roll out of site in an instance, especially if they hit hard concrete.
I've done that so many times that I freeze as soon as I drop something and listen.
If I listen carefully I can usually tell which way and how far the part went.
It's the second and later bounces to listen for, so you can lock in on a direction. 😁
I used to quickly look towards where something fell, but I can find a tiny ball bearing easier by listening more than looking.
C-clips are the worst !!
They like to take off flying and land in another part of the house. 😁
I learned to get my pliers lined up in the clip then cover it with a rag to catch it before I squeeze the handles.
Then it falls outta the rag so I still need to keep listening. 😁
Appreciate the advise and tips. Thanks guys
Another thing to consider is to pack your motor cable connector (and maybe all your connectors?) with dielectric grease when you reconnect it.
The stuff is messy, but you wipe it off the outside of the connector afterwards, and the connectors don't need to come apart too often.
The connectors can be difficult to get apart. Heating them up with a hairdryer helps.
They have arrows on them to show alignment, but they can be hard to see.
Yes, I had dielectric Grease at one time but been a while and have to check. Used it before working on a guy’s house with aluminum wiring (Aluminum is bad and outlawed since the early to min 1970’s) where connecting to short piece of copper wire to connect to outlet and have to pigtail the copper with the aluminum using a wire nut full of dielectric grease ( have to do this because of corrosion due to dissimilar metals). l used at work over the years at DFW International Airport in Electronics. BTW: Back in the 1990’s someone got the bright idea to install new power rails on the Airport Train system during expansion with Aluminum instead of the Steel originally used on the older parts. When they went to test the Phase Imbalance equipment that fed power it wasn’t adjusted right and to much current was pulled by the shorting bars when testing and the aluminum literally melted onto the guideway floor. The rails would sag in the hot Texas summer too. Also in a house with aluminum wiring normally if it were copper romex it would be stapled to a wall stud but with aluminum it expands and contracts with temperatures you cannot do that so it is just strung from one stud and hangs down crossing over to another stud. I used a stud finder and went to cut out a hole in the guy’s wall to add a wall light. I sawed into that aluminum romex. It was on a 20 amp breaker. If were copper it would have tripped but the aluminum just caught the romex covering and insulation in the wall on fire. I went out and manually tripped the breaker and used a fire extinguisher to put out the smoldering in the wall. I will not buy a house with that stuff in it.
No no no....
For aluminum and aluminum to copper connections you should have been using an Anti-Oxidant Compound/ Grease ... which is very different than dielectric grease as It actually improves current flow and dependant on application has micro bits of a conductive metal in it.
Additionally do not put dielectric grease on the bike connector conductors but a small amount on the plastic mating sleeves of the connectors which will increase their weather resistance but not interfere with current flow.
Right, 73 year old memory not soo good Gionnirocket. Been 1989-90 since last used. Thanks for the reminder. :)
Also, the tires I ordered apparently got damaged by the way they were shipped. The side walls buckled in 4/10 the area. It was a nightmare. I decided to put the original tire and tube back on the front (only one changed). It was easy and only took 20 minutes or less. In fact I was able to take the original off and reinstall with the tube (reduced pressure) back on without removing the tube. I could see there were no pinches (that was a shock). No way that could or would happen with new tire and tube. After 2 hours trying to install the new tire and tube I could see there was going to be issues (even if) with the tire and the wall on was extremely ridged on most of the diameter of the tire. I will not buy from Fat-Tire again. If I do buy another when I need it will likely be the Kendle. I should have gone that route to begin with. Talked with my wife and we both agreed to leave it stock (at least until I actually need tires). The noise I can handle, tire issues not so much. When it comes today I will put the Flat Off in the tires and going to clean and lubricate the chain.
The few times I purchased from Kenda... The tires came in a full size box, not folded or distorted in any way. Same with the tires I purchased from Bike_inn
They were 26x2.2 and 27.5x2.6 respectively, so no fat tire which may be the difference.
That said tires being folded for shipment is common practice and if you sit them in a warm place like a sunny windowsill they can usually be straightened out.
All my tires came folded over and then folded over again (¼'s), then taped up and shipped.
I managed to get them all installed.
All the tires are wire bead.
You'd think that the wire beads would break being bent over backwards twice, but no ??
They all installed nicely.
(after a lot of effort.)
