Gas cans and fun findings.
sc00ter
Norfolk, VA
I have a Honda Generator and keep a few gas cans on standby when a hurricane is coming our way. I'll try and get pictures up of the offending cans (actually one just went in the trash can) so you can avoid them. Anyways, back to the cans. One is a 2 gallon with a weird switch lever to open/close it. I used it today to top my moped up and the switch broke, no longer allowing it to close. The other can is a 5 gallon can and no matter what I do it spills half the fuel under the nozzle while pouring it. Both of these tanks are plastic and Made in the USA. I think the manufacturers forgot about the 10% ethanol content in gasoline, as I highly suspect both faults were caused by ethanol. Heck, I'll fish the other can out of the trash can for science so I can get a picture of it.
I also hate all these new safety caps they put on gas cans. I have a 1 gallon plastic gas can that's been thru everything and it still works great. No spills from warping of brittle plastic. Has anyone found a gas can that's worth buying? My work recently purchased a new 1 gallon gas can for our department and I swear I've seen people spill half the fuel every time they use it. It's hard to pour and even harder to refill. Stupid people purchased a stupid gas can at my job. I'll try and get a picture of that can as well. I know everything has gotten safety overkill but these new safety systems are just cumbersome and fragile.
I had to go online to see what is available locally. Based on what I saw, I'll continue to take good care of my simple "can with a spout and screw on cap".
You can buy replacement old style spouts for gas cans.
The 2.5 gallon can is so many decades old that I don't remember if it was a purchase or a gift. For a few years, it tended to leak around the base of the spout. A new gasket fixed that.
The 4 gallon can came from the widow next door about 10 years ago. It was old, and she didn't have the cap to store it with the spout inverted. That's fine because the yellow snap-on cap holds pressure, reducing the hazard of fire and of contamination by moist air. That spout is nice on mower tanks where I can't see the level because the flow stops when the level reaches the spout.
With a full can, fuel can flow before the spout is tipped into the tank. I can fix that by loosening the cap to rotate the spout 90 or 180 degrees, allowing me to tip the can farther before the fuel starts to flow.
When they made the nozzle dribble the gas into the tank at 1 gal per 3 minutes, I bought my last official can. Threw them away. I now buy diesel in 1 gal punch bottles, oil jugs, or 2 gallon weed killer jugs. Labeled with a magic marker, of course. Carry a funnel, they are not patented to be stupid. Buy fuel in the country, no-one is looking. My nearest station is in a town of pop. 400.
I quit buying gas when the B&S/troybilt mower was stolen. My 21" mower now uses liIon batteries. I tried to buy an electric pickup in June, but Lightning production was over for the year. No electric pickups with 8' bed either. Teslas pickups are such a joke. How are you going to reach over to get your groceries in the cooler? Open the tailgate? Carry them in your lap? My brother who runs a fleet of 6 4WD p/u says Chevy/GMC gets repeatedly occurring computer problems at 9 years. So Ford it was. 3.5 L engine gets 18 mpg.
Unless the power is out and I'm filling the generator, I only do 2 gallons at a time in my 5 gal jug. But I only use 4 or 5 gallons a year between mower, edger and snow blower.
I also bought a set of those Amazon nozzles and vents. My biggest problem is my tractor, it’s diesel and the filler is about waist or higher. It’s hard to get a can up there and in the filler without spilling. I bought a low dollar fuel pump and get a gallon or two out of the can and can then pour it in. $10 at Walmart.
One of the offending cans. The black pour spout broke causing it to no longer seal.
I thought it was just me totally piss'd with "modern" gas cans. The spring loaded nozzles make it frustratingly long to fill anything and always with spills. I gutted them so that it's basically a nozzle but the rest of the cap and gaskets leak if not painstakingly aligned and the design is flimsy at best.
I have gone back to just using a funnel with a legnth of 3/4" gas line attached.
This is the garbage I'm talking about.
Amazon has lots of "gas can replacement spouts" if you can get one with the right threads. Maybe they're standard.
I see this one has a flame arrester. In 1957, an older friend stunned me by fetching a tin 1-gallon gas can to pour gas on a trash fire. The spout caught fire and wouldn't go out. The arrester saved us. Around 2010, the fireman next door sometimes appalled me by using a 2.5 gallon can to pour gas on a fire. More recently, I discovered that another neighbor, a war veteran in his 30s, likes to burn wood in his back yard. The part he loves most is pouring gas on a fire.
I swear the engineers who design, and the regulators who pass the laws, never use these "safety" gas cans.
I just gave up on cans designed for gas and use these potable water jugs instead:
I buy my gas at self serve gas stations and have never been questioned. If I ever do, I'll just paint the jug red. I also buy ethanol free gas to avoid any potential problems.
I usually use a battery powered hand pump to fuel my small gas engines from the jug and never spill a drop. I did find a screw on spout from one of my old busted cans that fit the new jug for filling larger tanks.
Funny to hear a bunch of ebikers talking about gasoline cans. Of course you hate them! :D :D
Seriously, I totally agree with you guys. Every type of no-spill can I’ve had to use in this century has sucked massively. They break easily, they don’t do their jobs of not spilling, and they are just stupid.
Around here the VP Racing jugs are popular.
"VP Racing 5.5-gallon capacity container can be used to store, carry, and disperse animal feed and attractants, water, and other outdoor products but should not be used as a portable fuel container."
See, they're sold by VP Racing Fuels, Inc., but you're not supposed to use them for... fuel. Uh-huh.
( wink,wink) I suppose one could go to the trouble of getting a self contained motor board tank or "gas station" tank.check garage sales out and see if you can find the old "eagle"or "ironside" fuel cans,the gas cap off an old "B&S" gas engine fits the neck perfectly on the old cans,elect me president no more triple A or quad A batteries,standard sizes for food containers,waivers on usable fuel containers return of glass sealed beam headlights,more analog gizmos on cars and deer resistant front ends for cars(urethane) no more strip mines,endorse thorium reactors make sodium batteries more accessible to start,more cooperation with world gov;t and really come down on terrorists and drug cartels( much as I hate to admit it Trump seems to be kicking some badguy arse) wow might need 2 terms to get everything fixed and the one thing that will get me assinated no more taxhavens and the rich will pay their share of the taxes finally( another argument) vote KLM next election!(btw,old "tide" jugs used to work good and HDPE pretty well will at least stand up to ethanol-dont know if alcohol will affect HDPE or not remember organic chemists use glass ware basically( Carpe diem!) as Columbo sez[one other thing] check Steve Harris"Dollars to Sunshine", g'day".
