scrambler
 - USA
- City
 - Bay Area, CA
If a 60T sprocket does not fit, we can look at 19/55 (see below). For that @Ravi Kempaiah needs to confirm how much range there is at the rear axle to move the wheel forward or backward.
			Untighten the wheel, move forward to take the belt of the sproket, remove wheel, open the rear triangle, slide the belt out through the opening.Curious, what does it take to change the belt on this bike?
This option takes it to about 2.9 and that is great! I will send a note to Ravi and ask.If a 60T sprocket does not fit, we can look at 19/55 (see below). For that @Ravi Kempaiah needs to confirm how much range there is at the rear axle to move the wheel forward or backward.
I would only consider it if 60T does not fitThis option takes it to about 2.9 and that is great! I will send a note to Ravi and ask.
Note sent to Ravi and Zen Sales.
As you can see you are in good hands so don't throw the baby out with the bath water just yet.Ravi and I had a informative phone call. While Ravi was adamant about increasing cadence, at 78 years old I am not sure I will ever be able to maintain a cadence of 75 for hours at a time. I guess I have to accept that I am now an old fart and that my marathon days are over. I guess that leaves me with a few choices. The first being buying another bike or trying to convert the existing one so I can enjoy it. After not riding for about a year I know that picking up the cadence will help. Rather than spending the money on another bike I have decided to adjust a few things on this bike. I don’t have the skills or tools to modify the belt system and the two tiny bike shops in my little town have declined on working on a belt system, so the bike gets transported to Boise Idaho on Thursday. I will have them contact Zen Sales and explore if it is possible to adjust the 2.5 ratio closer to 3.0. If that is not possible then I wonder if it would make sense to replace the Rohloff with a standard 11 speed gear set.
Going from 22/55 to 20/60 basically shifts the lower gear by a little over one gear.With 60/20 external gearing, all of those speeds would increase by 20%, but I'd worry about the effect on the 35% climb the OP faces on every ride from home.
Ah yes, just found a photo. If the belt's that easy to change, inadequate wiggle room on rear wheel position might not be a deal killer.Untighten the wheel, move forward to take the belt of the sproket, remove wheel, open the rear triangle, slide the belt out through the opening.
One way or another, hope you get this bike tweaked to your needs.This web site has some very knowledgeable and very helpful members. I am totally impressed. I think by changing the rear sprocket and riding on a regular basis this bike will certainly work out.
Well the issue is that Gates does not make belt for every number of teeth, so you always have to check the chainstay for the closest available belt, and see if the bike can accommodate the small change in chainstay...Ah yes, just found a photo. If the belt's that easy to change, inadequate wiggle room on rear wheel position might not be a deal killer.
If your shop can fit the 19t rear without changing the belt or front sprocket, that would seem a good next move. You can enjoy the benefits while your cadence comes up. At 67 RPM, 55/19 will give you 15.9 mph in #11.A couple of things, first I did find a bike shop that has experience in gates belts and rohloff axles. i did do a 20 mile ride averaging about 17+ mph on the flats in gear 14. I am not sure that moving that speed down around gear 11 is going to make it any harder to pedal, but it will allow me a couple of gears to go faster if I have the strength to pedal. Like Jeremy said, I can hope to get my long ride average up a bit but am old enough not to shoot for the unachievable. My legs are still pretty strong from lifting and carrying heavy objects and living in the mountains means every walk is a combination of uphill and down hill. But fast I am not!
I think the 80 - 90 range is the high average for the novice cyclist so going above that is a ceiling on most of us without some serious training and a time machine. I think working up to 75 is within the average humans capabilities where 95 is starting to push boundaries.With the stock 55/22 gearing, the OP would have to pedal at a sustainable 78 RPM to cruise at 16 mph in 11th gear. That's a long way from his preferred 60 RPM. He's clearly an experienced cyclist, so we have to take that 60 RPM seriously.
How much cadence can he expect to gain with realistic training? I went from a tight 75-85 range to 80-90 in a year and 2,000 mi of casual hilly low-assist riding after 20+ years away. That 5 RPM bump brought me back to the cadence of my youth with no further gains in the 8 months since. I'd need serious training to get much higher, and I'm not about to spoil my fun with that.
He actually sounds stronger than I so that's why I think he can, I think he can...The OP sounds like a stronger cyclist than I am at about the same age, so maybe he can add more than 5 RPM with realistic training.
That's why we have ebikesBut going from 60 to a sustainable 78 RPM sounds pretty implausible. He told us flat out that even 70 RPM is unsustainable now in 11th gear at 16 mph.
I say ride both of them.I think the hardest part is going from a road bike averaging 22 mph and weighing about 20lbs to an E bike weighing close to 80lbs. But I will make a few changes that are more bike fit related and keep on riding. I can always go back to a 22 if needed.
We have not checked if 60T would work. I will check with our team.60T gates sprocket would not interfere with the rear arm!
