Do you have a low voltage cut-off set? With the Photon, that will take effect during a stress dip into low voltage.So today I did a little around the block experiment under throttle. I have a short loop, maybe 1/3 of a mile with a 80 feet of elevation over the course of the loop. First lap, motor cold, I did an full throttle loop at speed. The bike completed the loop and I was at full speed. I was in race mode 3 for all these tests. Measured 118 F on the motor at the end. Ambient temps were low 60's. Output was hovering around 1200 watts, but I had the setting for number of magnets at 6 (I have one) so I was reading around 4 mph at full speed. Second loop, I fixed that and set speed limits to max on both race and street modes and the motor dies on my at about 1/4th of the loop. No overheating as temps were about the same. Came back to start, and went a third time with no changes, made it 7/8ths of the way but I kept it under 28 mph so I wouldn't hit the ceiling. Died and I pedaled the last 8th.
Sounds to me not that I am seeing overheating in this scenario, but that I have some kind of software issue that kills the motor when it hits a weird state. Anyone else have any issues like this? Any ideas from more knowledgeable folks are welcome.
Lastly, I emailed technical_support@cycmotor.com a few times over the past weekend, but no replies. Are they typically poor regarding support?
Thinking along those lines, hitting LVC on the battery side would disable the battery until it is plugged into a charger again. It wouldn't even be a motor issue. Something else to check.Do you have a low voltage cut-off set? With the Photon, that will take effect during a stress dip into low voltage.
I totally agree and that's why you're the perfect candidate to try this motor firstI am developing a far greater appreciation for imperfection. If you wait until conditions are perfect before moving ahead, you will never get anywhere. The same goes for the motor manufactures.
I just replaced my Box 2 XW Prime 9 that has a 12-50T cluster with an Advent X using the steel 11-48T cluster. I'm absolutely loving it. the only down side is the shifter is not single-shift, so I have to take care to shift just one gear, which hasn't been a problem.I was interested in the micro shift Advent x, but I already had it in my budget to replace it if I didn't like it. If I go that route I'll probably get an eight or nine speed ebike specific cassette.
Weight is not a factor for me, the relative weight of a cassette will not matter compared to batteries and motor and other electronics I'm strapping on this thing. Strength is the thing, even without the motor I put a strain on bike drive trains, adding the photon is going to mean some fast wear.The nine speed cassettes can give a strong chain and wide range for a moderate replacement cost. Here is a nine that is 11-42 for $24. If you are going to be replacing them every quarter this kind of thing is better than $240 cassettes. So what if it weighs a little more.
I'm coming from a dirt bike background, long distance exploration and racing, along with hare scramble racing and being my son's race mechanic for 10 years. When I would jump on my dirt bike I knew exactly what spares to have and how to carry them.I have a big guy friend with a couple of powerful bikes. When I cut and prep a chain for him, I will do two at the same time. You have the supplies and tools out, so why not? That way he always has at least one spare chain with a quick link on each bike. We also make sure he has spare cassettes. Once he lost a quick link and dropped a chain while on this steep hill where there is no cell reception. He had to walk to a farmhouse and ride back in a tow truck.
Cool. It is mostly the internally expanding chain parts, pins, guides, rollers, that wares cassettes and rings. So, changing chains regularly with advanced maintenance extends everything else. Dirt is like sandpaper grit. With new chains I clean them of all shipping gunk and black manufacturing grit, then soak in some nano-wax that does not attract or hold grit.Thanks
A couple of years ago I looked at hydraulic drive. The problem is that the system would require large hoses and too much fluid weight for a bike.hydrostatic drive
It sounds like you have your priorities exactly right. Experienced cyclists have to leave behind some of what they've learned to successfully make the transition to a DIY ebike world.I'm finding it very fun learning all that stuff over again while having a very different relationship with weight. I did have quick links on my spares list, but at the rate I'm going to go through cassettes, having an extra chain or two on hand will probably be the most efficient way to manage those and give me spares. Thanks for the idea!
