Looking for some big batteries for the house, too. I will PM you.Looks like I missed the party. Thanks to the weather here, I have been running my house on batteries (big ones) since Thursday nite.
Trying to catch up on everything at once, its possible one stone is left to turn: Creating an absolutely steady load on the battery pack to eliminate that variable in the discharge test. Noted some questions on throttle draw vs. PAS draw up above.
I use these, albeit for practical reasons (Usually to take a 100% charged pack lower if I charged up to ride, don't do it and don't want the pack to sit like that), not for test purposes. This may be a little heavy handed as they create a steady 7a on a 48v pack. But for $28 they are an inexpensive tool. Also dangerous as they get up to around 500 degrees so set it on a brick on top of a cement surface like a garage floor. Set it straight down on a painted garage floor leaves scorch marks.
I have seen DIY banks made that use a row of cheap light bulb sockets. Maybe not so good anymore now that LEDs only pull like 3-5w.
I wrote out the numbers and stuck em to my power supply for quick reference,..
It looks like your percent gage is off.
80% is 51.5v and 100% is 54.6v
So use your volts display instead. It's accurate.
PCDid you use batteries #1/2 or is that what they are reading after the light turned green and you unplugged the battery from the charger?
I have a second GRINSPECTOR kit. And have decided to not continue with any battery testing, or repairs.Looks like I missed the party. Thanks to the weather here, I have been running my house on batteries (big ones) since Thursday nite.
Tempting Tom, but I'm also getting away from working on these batteries. I'm not expert enough and there are just too many risks. I'm not using questionable aftermarket batteries anymore and deal only with quality name brand pre assembled products.I have a second GRINSPECTOR kit. And have decided to not continue with any battery testing, or repairs.
The display % is not accurate as compared to the Voltage Reading.
PC@Nvreloader try charging one of your batteries that has shut down for just a few seconds or a minute.
If that battery was at 50% voltage maybe all it needs is a few seconds of charge to reset the BMS.
It's too bad that you can't reset the battery by simply removing and replacing it.
I'll change the display back to Voltage, as it is accurate in the readings,
when I compare it to the VM etc
PC
Just checked the #4 batt
Was at 19% = 45.9v at the end of the ride.
This batt now reads @ 38% = 47.2v
After sitting all night, and was NOT on the bike.
Tia,
Don
As far as I know, those are high quality cells.PC
These cells are LG 21700 brand/name.
.... but that said, 5a divided amongst 13 cell groups is far from ridiculous.
