Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
As long as you monitor you should be ok. You still have the BMS Overcharge protection if the charger is still outputting after the green light on the charger indicates a full charge.
It takes a bit of skill but implementing an inline voltage / watt meter will remove all the guess work. You can even use a multimeter but that will require a charge extension cable or hacking into the charge cable itself.
My little hack on the subject. . .
electricbikereview.com
$10 DIY Smart Charger Alternative / Ver. 2.0
I've been experimenting with an easier way to achieve a 70% - 90% charge or a storage charge for my battery other than just timing it and I came across an inexpensive solar charge controller that I thought I might be able to adapt. In the end I am able to achieve my goal, but it didn't end up...
