Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
Aren't motorcycle cables in housing throughout?After many Years as tech at Motorcycle shops - this clever cable lube tool has been the standard since
early 70's. I'd be surprised if bike shops didn't have version to fit the smaller cable housings.
A good Teflon lube with spray tube attached enters rubber grommet and then gets clamped down
on cable & housing where lube is forced all the way to other end. Some Teflon grades for chain
I've used on my ProMotocross, and cables never needed lube after twenty years.
I think the issue with bicycles is the exposed portions near ground and sometimes at a down angle
