What's NOT said about Suntour NCX seatpost
In the process of setting up a new bike with new NCX seat post, and just wanted to share that after flipping that top bracket 180 degrees, I found myself too far forward without enough real estate ahead of me. Post functioned perfectly.
Point being, flipping that top bracket is not going to work out for everyone - though I can certainly see the logic behind the idea!! Noteworthy is the fact there are not many guys my size riding bikes (6'1"/315)
I concur... I have no need to flip the top bracket and if I did I'd be too crammed towards the handlebars.
I do think that having the option is coolio and glad someone used a little common sense/problem solving and posted it.
So far I prefer mine with the NCX seat mount reversed, more fwd position. I'm 182cm 70 kg, Cannondale Trail 7, casual urban riding with a few dirt roads.
I'll review it further when I've tested it more.
I like the change in geometry. Makes a lot of sense. That's why I changed it before even riding the bike!
The seat binder bolts, I stripped one of them, so I can't loosen it to get the seat off. Does anyone have a suggestion for loosening the bolt? Yes, I always tightened the bolts to 15nm.
After a few 100km's with the Brooks B17 and NCX seatpost I've changed the seat mount position back to standard from reversed. This positions the mount further rearwards, and I run the Brooks B17 seat set forward in the mount.
As mentioned by others, the Brooks B17 seat rails will rub against the front linkage of the NCX seatpost unless the seat fwd/aft is positioned most of the way fwd, or you reverse the seat mount (explained earlier in the topic).
There's around 45 teeth on the NSX to adjust the seat tilt angle. Thats around 8 degrees per tooth. I found it put the Brooks B17 seat tilt angle either down too much, or up too much for my liking.
My remedy was to insert thin washes between where the teeth mesh, adjust seat tilt to my preferred angle (roughly level in my case), drill 2 holes each side with a 2.9mm drill bit, and tap in 3mm dia stainless steel dowel pins.
So far so good. A few things to note:
I determined the right tilt angle for me by test riding with a 2 bolt micro adjust seatpost.
When the Brooks B17 is new, nearly any position wont feel comfortable. Let it wear in before you think about modding the NSX seatpost, imo.
You can do the same mod with the NSX seat mount reversed, but the drilled holes wont line up if you change back to the standard position.
Absolutely not. What I did is remove the 4 set screws which hold the roller pins in place and pushed out the pins; reassembled the lower part as per how it came (had to remove this lower roller pins to get to the upper set screws); then flipped the top part + seat mount around so the seat mount is almost inline with the post. It works the same as it came when new, it's just the seat mount is about 1.5" more forward, and higher, which allowed me to drop the post further down into the tube.
Hopefully this picture helps show how the seat mount is more forward and higher than the original position:
The stock location from Suntour has the seat mount back much further and lower.
After reading Avg Joe’s method here I pulled mine apart and reversed the top link. Took all of maybe 20 minutes and now mine also looks like his pic. I haven’t tried it out yet (hoping for in the morning) but it looks like a “no duh” solution to the problem.
Many thanks, Avg Joe!
Brilliant advice, thank you. I flipped mine as described and the saddle sits where I want it to be, so the saddle is now level rather than nose up. I have not noticed any other difference in the ride, so very happy!
I'm riding a different bike then when this was originally posted and ended up giving this solution a try.
Though it did move the seat position a bit forward reducing reach, I definitely noticed a difference in performance. The post no longer handled the smaller bumps as well as the factory position. I switched it back and purchased a handlebar with an offset to shorten the reach. Much preferred solution in my situation.
ymmv
I've had the Suntour NCX seatpost on my Rover StepThrough for a few hundred miles now, and have been fidgeting with my riding position. Today I had an epiphany: The seat offset on the NCX seatpost is pretty extreme when compared to others - the seatclamp is at least 1.5" or more rearward vs the factory rigid post. This was not something I was aware of when I bought it due to my own ignorance/newness to bikes and components.
I have been experiencing some post-ride discomfort in my wrists, elbows, and hips. While riding today, I realized how far behind the crank centerline my hips were. Even with my seat adjusted forward to the limit, I'm really reaching for the grips and hunched over; and it's almost like I'm push-pedaling if that makes sense. I'm not looking for a cruiser position, a quasi-"athletic" position works well for me. But this is rather extreme.
I'm putting my rigid post back on tonight and will see if this discomfort subsides. I am also looking at suspension seatposts with 0 offset, not interested in the $200 posts as I want just moderate suspension (I run my Innova 26x4's at 16 psi which helps a bit) and no need for the parallelogram/elastomer design - a simple spring is plenty for me.
Ergonomics can make or break a long ride. Good on you for listening to your body and switching back before causing any serious strain or long-term discomfort.
