Having gathered information for some time I just recently found out about this forum that appears like THE ebike forum - especially for DIY which is not a big thing in my neck of the woods.
I am considering swapping diesel for pedals, for commuting 30 km one way. That will not happen without electricity since I am nowhere near fit and do not expect to be able to keep up a speed that covers the distance in reasonable time. Also I need to be able to actually work when I get there...
Distance is 30 km, essentially flat but headwind at times. I am around 200 lbs and need a minimum of baggage. Reasonable time for me is around 45 mins at the most, so ideally need to sustain at least 40 km/h (25 mph).
From the Trip Simulator at Grin webpage I realize that this will take a bit of battery. I can charge at work but that of course also means twice the cycle count. I am free to choose motor type, bike model etc and optimize for this specific application and this is where I would appreciate experienced input.
I lean towards a hybrid type bike or possibly mtb, with a half-forward riding position, 26-28". For simplicity I am happy with rim brakes.
As for motor - I believe that a direct drive hub motor would be nice for several reasons, but I really want to avoid a large hub that draws attention. Hence rear wheel would seem better = more discreet. Or a geared hub motor in front, IF they stand the wear in this application. Motor weight is not a big issue though.
Mid motor might also be an alternative but since I will be going long distance with continous fairly high power I suspect that chain/gear wear may become an issue.
I believe that 750 W or so would do the job but here again I am out in the deep end. Better to go for smaller motor at higher load or the opposite?
Maybe the biggest question for me is if battery requirement will be the killing factor, both money- and size-wise. Maybe it is too big a bite to chew...
Budget is of course an issue too. Aim is for drive kit in total (just kit, not bike) not to exceed EUR 1000 (roughly USD 1000), does that sound doable or must I step it up?
If/when this project comes to real life, I will of course share the proceedings.
