I’m having issues with a new chain(s) which I fitted to my Vado 4. It happens with both Shimano and KMC chains. I thought originally it might be because the Shimano chain was different from KMC(fitted when the bike was new), but fitting a new KMC chain causes the same problem
The problem is that under torque I get a grinding type noise from the rear derailleur. If I apply the brakes lightly when pedalling slowly it makes the noise and if I look back I can see and hear the tension pulley and cage rattling.
if I put the old chain on again, all is ok.
The old chain is fairly worn so I am wonderimg if something needs adjusting to accommodate the new chain?
Any advice appreciated.
