Your experience might vary from mine, Marcela. My older Vado 5.0 came with a rigid fork. I raised the bars with a stem riser. Then I added some suspension with Baramind handlebars. And, which is important, I use Ergon GP3 grips. All these actions made my riding position pretty moderate, with no excessive leaning on the bars.
The 2022 Vado looks far more comfortable (without the modifications I've just mentioned).
FIT. Stephan, above you say 2022 Vado
LOOKS more comfortable, but don't you actually have the 2022 Vado? In practice, it would be good to know that the effect of all the geometry change made is one ends up with a more comfortable bike. I looked at all the geometry changes for the Canadian version of
Turbo Vado 5.0, L and XL sizes, between the 2021 version and the 2022 version. So many measures different. For 2022, higher numbers for stack, reach, headtube length, trail, front center, wheelbase, and stand over height and lower numbers for stem, chain stay, crank length and seat tube. So i was wondering what to think what would all these changes would make for fit? At 6'1" in the
Specialized sizing guide, they say, for either the 2021
or the 2022 geometry, I am right between either the L or the XL size. Fit is very personal. For 2021 i needed an XL with a longer and higher stem. For the 2022 V5.0, which i would like to get, I am not so sure what the geometry change will mean for me. Or course no one has any in stock to actually sit on one.
MOTOR. The other difference between the 2021 Vado 5.0 and the 2022 Vado 5.0 is the motor changing from 1.3 to 2.2. Do you know, what is the difference and how does this affect the ride?
WEIGHT. I asked and was told the whole complete bike in a large is 58lbs and the 710wh battery itself weights 8.75lbs. I was hoping for less, as I think the 2021 weighted in at around 50 lbs.
ONE BIKE. I can see why you like the Vado SL. I rode the various models, and found the higher end carbon model was much nicer to ride. In Canada I recall that, for the way they set the bikes up here, I think Vado SL can take fenders, but not a rear rack or a kickstand, which I would like to have for a 1 bike fits all approach. Yes, the heavy Vado 5.0 + much lighter Vado SL 2 bike approach is relevant for different uses. If i had to have one bike, it would have to be the heavy 2022 Vado 5.0, given the variety of cycling I do, but in the future I am hoping they get can get the weight down, as a heavy bike feels like a heavy bike.
