You Really Do Get What You Paid For (Motors)
Brands will continue to spec bafang because of it's better spec to price ratio on paper.
This entails numerous problems for the consumer after purchase, however. Bafang motors are notoriously noisy and as many have pointed out, controller programming out of the box is poor, probably geared towards lurching, high powered starts which gives the impression of power, but becomes a liability for control and therefore safety.
Meanwhile brands such as Shimano are offering a superior user experience out of the box: quieter, smaller motors, lower Q factor, integrated batteries, and of course, a much more refined, linear power delivery.
You're paying more but the level of refinement is almost night and day.
Refinement and also somewhat slower so you won't hurt yourself.;). Be careful on those moms with strollers passing you.
RE the original OP's comment on the Aventon hub-drive. It has nothing to do with the Bafang Motor , it's the Aventon's programming that was universally awful. Not sure if they ever improved it.
Plenty of vendors don't have that problem.
I don't use Bafang. I have a bike with a Bosch drive. Saying that, it's not fair to Bafang to blame them for every bike maker's mistakes. A bike maker can spec the DU and controller they want to put into their bikes. As others have pointed out, when properly programmed, the Bafang controllers do a good job. Let's put blame where it belongs, at the feet of the bike manufacturers/assemblers.
rhythmic squeak
Great discussion everyone. The squeak could be the main bearing when it warms and is under load.
I am installing a new motor today on a favorite bike. Not because I need to. Because it has three years of service and the main bearing is starting to get sloppy. I depend on these bikes. It is a lot cheaper that maintaining a car. So why not? I have all the parts and I like things that are fresh and tight. As some of you know, I like the small, lightweight mid-drive torque sensor kits. I chop off the speed sensor and use the kits that cannot have cutout levers and cannot have throttles. No extra wires. I set the wheel diameter at 100cm and the speed limit at 45Km. Those settings are for 700c rims on 29ers and 28 inch bikes. That makes the real limit essentially unlimited or about 2.3 times faster. These motors are quiet and smooth and feel like the high-end bikes. Here are a couple of builds from this week. And a build from last week that looks wireless. That Marin is my cleanest build to date.
Bafang BBS02 and BBSHDs are notoriously silent. The frame-built mids were originally noisy but Bafang - eventually after an enormous amount of protest and widely available 3rd party solutions - changed the internal gear material to quiet them down. If you don't have that kind of gear inside your motor you can sub one in. Again the Linux/Windows analogy made above applies. That refinement is attainable with an afternoon's reading on the internet and another day or so of further learning while tinkering. If thats not your bag, then yes go write a check and be done with it.
Saying "impression of power" is a comment that poisons the well. They really do have more power. Its not just an impression of it. Again because they are more geared to a utilitarian mindset rather than to a recreational one.
As for "becomes a liability for control and therefore safety"... This is untrue. Even with the rough edges still on, a Bafang motor doesn't 'lurch' or run amok thru the countryside. In fact its never ceased to amaze me just how little that big power causes upset to the bike. Yes they start and stop harder than they should. This serves to piss you off but nothing else. I've got a 2500w Cyc X1 and its also not jarring. When I had a Cyclone that peaked in the 4000w range, it too didn't feel particularly powerful. The meters didn't lie... the power was there and being output. But if someone thinks a 2500w motor is ten times the punch of a 250w thats a thought that will be dispelled quickly by reality if they actually go ride one (hint: the controller is set to roll on the power).
The Chinese aren't stupid. In my experience they are very canny entrepreneurs, albeit often stubborn to a fault. Bafang certainly is in this category. But once they put their minds to seriously compete, they tend to crush - not just win but crush - their competition. In the long run I don't think this is good for the consumer but I think thats where we're headed. The current Shimano/Brose/Yamaha/Specialized motors will become niche players unless they adapt and compete rather than just trying to lock them out via legislation.. Its not like we haven't seen this movie before.
I'm thinking the same thing. I don't want the bike to go out of service for weeks while I play with it in my off hours, so a fresh motor and then spending a few months of weekends pecking at it is the way I'm going to go. I'll use this motor to finally go all the way and do a total motor tear-down (with no operational consequences if I screw something up), which I have never needed to do. I may even strip the motor down to its casing and remove all the black coating and polish it. I've seen that done and its amazing.
We are finally going to get the Bafang versus Bosch confrontation. Bafang has their factory in Poland up and running. The EU can't really do as much to restrict what Bafang does in the EU, if they produce in the EU. I've been building and riding ebikes for 8 years and a guy comes along, goes for a 5 minute test ride, and you say he is brilliant. Yikes. Quick would be the operative word.
Bafang knows they make a good product. They are partnered with Eunorau and they seem to have a lot of money. Bafang has Bafang Energy, to make batteries. Their 'forced' battery is about half the price of the Bosch 'forced' battery, double the capacity.
The problem for the US is that Bafang is not playing so nice anymore. Bafang talks about a small group of vendors for the newer models. That sort of suggests that they don't care if all these small Bafang dealers in the US dry up and blow away. People should spend some time on the Eunorau site. They are going after all the big name European companies.
I don't see the problems with any of the Asian motors I have used, Mac, Golden, and Bafang. Of course, I know how to ride an ebike.
I guess this is the new face of the Chinese ebike industry, at least in the US. He seems rather serious.
I have to tell you, they look like a charging up-comer to the Ebike world.
This can be miscontrued as petty; or "Gotcha!", but it sure helps if you, the company, can spell the darn name of your company correctly when you show a pic of the company founder and his history. Kinda makes the lack of attention to detail on something simple as this; makes me wonder about the product, the product's build, the product's warranty and the company's treatment towards their customers after the sale is made complete......
Instead of stripping a motor housing I painted one once with high-temp engine paint. Not a perfect solution but sometimes good enough is okay to not get stuck. I was impatient to convert an all chrome bike. I might do as you suggest instead of tossing the retired one. Maybe I will have time to work on it when things slow down in February. Good idea. Thanks.
Case in point.
The sondors "rock star" (which is anything but) might look great as a price vs performance bargain, but listen to that motor! (5 and 6 and 7 and 11 and 12 and 14 minutes in). Does that sound like a quality motor to you? That thing whines more than Luka Doncic when he doesn't get a foul call! (No hate, Luka is great :)).
I had a hard time listening to that thing for a couple of seconds. How is that going to grate on a rider after 2 or 3 hours?
Everything on the bike is supposedly "custom" and "premium" which is ridiculous. If everything is so premium why are none of the components actually listed? If the frame is "custom" why is there only one frame size?
If the frame and bike are "premium" why does it weigh EIGHTY THREE POUNDS?!? That's easily 30 lbs. heavier than any actual quality emtb. The company even had the gall to film a "roundtable" discussion about this bike! Come on guys, I love the price point too but pretending like this bike is premium in any way shape or form is a joke.
There is no relevant information about ETT, reach, head or seat angle, etc etc etc etc. What is the crank arm length? A single frame size with a 31" standover?!?
What you're getting here are cut rate components which are extremely heavy. Can you imagine lifting this bike onto a bike rack or hiking up even a single flight of stairs?
Shimano and Bosch motors in comparison, 3:30 in. Listen to how silky smooth the windup is on both:
The bafang ultra sounds like a loud, old broken down clunker, whereas the Bosch and Shimano are smooth like butter.
The rockstar sounds like my meat grinder! Not sure if it is brand new in that vid, but it should quiet down as the gears mesh with a bit of wear.
The gear in the Ultra is steel, and because of that, nearly impossible to destroy, even for those applying stupid amounts of power to it that amount to several times what the motor is rated for. See what happens when you try that with one of the "quiet" European motors.... if you dare!
That said, I'm not a fan of that noise either. I'll say it did quiet some after 40-500 miles due to break in. Also, I've read where we SHOULD have a composite gear available this fall that should hold up to the motors RATED capacity, and will reduce the noise level to that witnessed in the other large Bafang mid drives (BBSxx). Most owners rate those as somewhere between quiet and silent.
I have a Bafang Ultra, about 1500 miles on it so far. I have the max current reduced to 26Amps (about 1300W)
During a typical 2-3 hour ride I stay under 500W.
Max PAS/ throttle and low gear when the motor is spinning fast is the only time it's audible.
I rarely use that combination.
But someone doing serious aggressive MTB rides could annoy other riders (including me)
Bafang can't quite get it right it seems. Either their steel gear is sufficiently strong but too noisy, or their nylon gear is quiet enough but not strong enough. Pick your poison.
IMHO, they had it right when the first brought out the G510 with a composite gear. It was a noisy minority that thought they might have a lot of trouble with the composite, convincing Bafang to go metal, which we are now stuck with.
Noteworthy is the fact the Bafang BBSHD is rated for the SAME power the Ultra offers (160nm), uses a different but very similar setup as the Ultra, has a GREAT reputation as being rock solid, while using a quiet composite gear.
Maybe they DID get it right: I'm willing to bet you that the speed freaks don't really care about the noise. They want power, period. Noise may even be a feature, not a bug. The more leisurey riders can choose to have a quieter drive. You have a choice.
This is exactly the case. The whole steel gear thing was driven by the hot rodders who were more or less melting the nylon gears originally in the Ultra - on controllers that were also running 2500w+. This is also why there are steel BBSHD gears available (and controllers that also can pump out 2500w) and the BBSHD with a steel gear is noisier.
The guys who tear into these motors do not, in fact, care about the noise.
Sondors created that bike as something that is meant for the formerly beginner ebike rider who wanted to step up to a higher level, to something big and kickass. No high end emtb rider was ever going to like that bike and this was known. Think about it: What emtb rider is willing to ride with a 50T front chainring?!? And a 21ah battery? You want to know where that extra 30 lbs comes from? That battery is a big chunk of it right there and a proper emtb doesn't need a battery half that size. I know on my enduro powered by a Cyc I learned very quickly I could ride until my ass gave out and I was barely 25% into my 20ah pack, which has been retired for a 12ah 25R pack that is still bigger than what I need. I could hang a little Mini pack under my saddle and be just fine.
But the Rockstar customer is at best going to be riding groomed trails and XC. You see people putting racks on them. And handlebar baskets. For that customer, its a perfect bike and I see rave reviews of it almost daily from its new owners. None of those people are singletrack shredders, but then again the bike isn't meant for them.
I pounded on the nylon gear for close to five years with zero problems.
Same here I have 5 bikes with BBSHDs on them and I have never had an issue. The guys who peanut-butter the gears are the guys running 60v, 2500w and 3rd party controllers from places like HPC. Run the motor at its factory limits of 30a/1750w on a 14S battery and it will literally run all day in 100 degree heat.
Sonders also designed a frame with no regard to weight. It looks like they had plates welded together, rather than use hydroformed tubing like other builders. Hydroforming allows much better control over tubing thickness and stress points, and round or oval tubing is much better from a strength to weight ratio.
Yeah oddly enough the 'little' Sondors Fold is hydroformed so its not like they couldn't do it. At least they didn't put a 7spd on that one like they did on their other two mid drives; instead opting for a pretty decent SRAM 11s drivetrain. But as for round/oval tubing... remember they had a mandate to use the common 21ah/48v battery pack and that monster pretty much dictates a squared down tube. Its not a great choice for mountain bike riders but again that bike is shaped like a serious mountain bike, but its not meant to be one.
