kahn
- USA
- City
- northWET washington
Okay, two times it may be because I forgot to re-engage the damn clutch. In my favor, I've never had a clutch before so ....
But today it jumped off on an uphill and the clutch was engaged. When the chain does this, it appears to want to make life difficult for me and jumps off toward the inside. It then gets jammed between the bulge in the motor housing and the chain ring. Each time, I have to work carefully in order to not kink or bend or whatever the chain. Took five minutes to disengage the jam.
I see there are "guards" but most seem to attach to the front derailleur hanger or similar. The Creo's downtube is a bit on the THICK side. Not sure that anything can be anchored there.
Ideas? I don't think there's an adjustment screw as there would be if there were a real derailleur.
Thanks in advance
Thanks in advance
