PowerflyLee formerly known as CheetahLee
I just wing it, trial by error
			Thank you for your response William.I'm very sorry for everyone dealing with Nyon navigation issues. I'll share your feedback with the team(s) this morning. In response to Steve's feedback from last week, I got additional people involved, so hopefully we can make more happen.
Thank you for this!Thank you for your response William.
I've noticed in my city that some dedicated cycle paths (in streets, separated from cars and with dedicated traffic lights), that have been established for a few years, are not shown on the ebike-connect map but are on the source OSM map. Furthermore a route created with the web-based ebike-connect with start and finish points on a cycle path will deviate to streets.
Also, I have found that a GPX file with 1 km markers will load into the web-based ebike-connect (not displaying the markers) but will not load into the ebike-connect app.
Interestingly the recent ebike-connect app update release notes states that the maps are "as of October 2020".
Hope this helps.
Regards
Peter
Just want to chime in that it's not just a Nyon issue. Routing is just as bad (but slightly different) through COBI on the SmartPhone Hub.I'm very sorry for everyone dealing with Nyon navigation issues. I'll share your feedback with the team(s) this morning. In response to Steve's feedback from last week, I got additional people involved, so hopefully we can make more happen.
If you need a tester here in NYC, please let me know, I am shocked the last update made it out the door, I work in tech and manage a large team of devs, many people would have been looking for new jobs had that happened on my watch.I'm very sorry for everyone dealing with Nyon navigation issues. I'll share your feedback with the team(s) this morning. In response to Steve's feedback from last week, I got additional people involved, so hopefully we can make more happen.
And the 625 will fit where the 500 goes?So, I stopped into the shop the same day and had an opportunity to chat about the problem and decided to purchase a 2nd battery for my bike (upgrading from a 500 to a 625 PowerTube).
Yes, the Trek Allant accommodates the 625.And the 625 will fit where the 500 goes?
Yes it does. So does the Rail 5.Yes, the Trek Allant accommodates the 625.
You cannot overcharge it. Just keep the battery plugged in until you get up.don’t want to over charge.
Is there a spring mechanism in these Trek bikes whereby it keeps a 500Wh Powertube steady in a 625Wh space or something?Yes it does. So does the Rail 5.![]()
Thanks, is the spacer easily removable eg. Could it be used with any Powertube 500 to fit in any other bikes 625 slot?The 500W PowerTube for Allants and other 625-enabled bikes, has a spacer filling the gap-length of the 625W.
The 625 Tube is longer. Also, just found out my LBS has my back-ordered 625 battery from Bosch — now waiting for the Trek skin.
Just make sure the battery type/orientation (verticle or horizontal), is consistent with the battery compartment and the orientation of the male battery terminals on the bike.Thanks, is the spacer easily removable eg. Could it be used with any Powertube 500 to fit in any other bikes 625 slot?
William, this is great info. I found similar charging instructions within the excellent Bosch manual “The ebike Battery Guide. https://www.bosch-ebike.com/fileadm...ike-Battery_Guide_MY21_US_CA.pdf?_=1608539234The Bosch battery will automatically stop charging when it is full. Overcharging is not a concern.
