MrCaspan
I have been looking for a simple outlet that allows me to set 2 timers. A delay timer and then a length timer. When charging my ebike battery to get the most life out of it I don't want to charge it after a long run when it's hot. So I normally wait 2-3 hours then charge it for like 5-6 hours. Problem with this is that I can A forget to put it on the charger after it cools down or B forget to remove it from the charger for long periods of time. So if I could plug it in right away and delay the charge by 2 hours then once it turns on it would only charge for x number of hours. I have found tons of timers that let you press a single button to toggle between 1,2,4,6,8,10 hours but I can't seem to find one that exists that has a delay start on it. I'm looking for a simple solution not super complicated and no more that $40. Any ideas?
