Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
I think everyone is missing what the op is trying to accomplish.
Typical timed outlets do not meet his requirement.
I could care less if you use my ideas I gave you several of them and you wanted some magical solution . you want to do things that are just not really practical. you want automation that thats not automated. there is a device that pushes a button it can turn mechanical switches on and off it runs from your phone and can be setup to run on a schedule. you get that and a wemo set to turn off after on 6 hours. you set a timer on your phone for that device to push the wemo button in 2 hours that turns on the wemo then the wemo will turn off in 6 hours and your done. rinse and repeat every time you need to charge your battery. spending on the device it may be able to send you a notice that it has happened. another solution by a wemo and a mechanical timer. set the timer for 2 hours off 6 hours on set the wemo for 8 hours on. you start the demo with a button push or your phone it runs the mechanical timer the timer runs the charger then turns off. you will have to turn the timer to the start each time you use it. or even easier buy a second battery.Anyways it should not matter why I need a solution nor should I have to justify it. I thought that maybe the community had some ideas. If you can't think of any other ideas please don't be rude because I don't take the first advice that came along that I had already thought of. I had the solution of a smart plug the 3rd post and if I cannot find a solution that's a simple one I will use the smart outlet route. If you don't have any other ideas to contribute I am not sure why it feels like you are getting frustrated cause I won't settle on an answer after 2 opinions on the subject. There is alot of community knowledge out here and want to wait to here what others do is all. Maybe something neither of us thought about! I'm an open thinker and do IT for a living, I don't just settle for duct tape solutions because there are free or I don't want a better solution.
No, it's pretty straightforward:. They want a 2 hour delay before triggering an 'on' state, then they want the 'on' state to turn off 6 hours later and they need it to not be schedule bound or auto repeating. It's just not a combination typically found in timers.I think everyone is missing what the op is trying to accomplish.
Hahahaha...I know exactly what he wants to do... It's the replies he's getting about timers I was referring to.No, it's pretty straightforward:. They want a 2 hour delay before triggering an 'on' state, then they want the 'on' state to turn off 6 hours later and they need it to not be schedule bound or auto repeating. It's just not a combination typically found in timers.
The only practical mechanical way I can think of using off the shelf countdown timers would involve setting up a lamp on a simple countdown timer and the charger hooked up to a separate countdown timer with a photocell on it(like they sell for holiday lights).
OP could trigger the first timer when they park the bike in the garage, the lamp turns off 2 hours later triggering the second timer to turn on the charger for 6 hours. Should work, but in practicality is just trading out different failure points for the ones the OP is trying to avoid (internet failure or forgetting to unplug the bike).
@Gionnirocket Sorry I didn't even see this reply. This looks doable! I would just need a project box to put this in and stick two power squids coming out for my 2 bike batteries at home (Mine and my partners bike).I don't think that you will find this ready made for home use especially now that smart outlets are so common and probably your best bet.
If you are somewhat handy, you can definitely build something as ON_Delay/OFF_Delay relays are very common for commercial/industrial applications.
Here's an example
The solution for work I settled on is just a 24 hour mechanical timer set to 6 hours ON. At our office we are very environmentally responsible and don't like having phantom loads on if not using them. So this solution Crank it to 2 hours before the timer comes on and unplug it when I leave work. At home this would work 90% of the time. But we go riding at all times of the day and some times twice so I need a solution that works 2 hours AFTER I plug it in for homei use this, works like you want it to.. starts at a given time, stops after given time.
you have to program it. I always arrive at the office around 9:30 - 9:45 am so I have it set to start charging at 11:30am, I know it takes 4 hours to 4.5 hours to charge my bike, so I have it shut off at 4:00pm. 8 months no issues.
use the same unit at home, starts at 10pm at night and shuts off at 2:30am. every once in a while I note the battery is not at 100% but close enough. 100% on my bike is 54.5volts occasionally I see it at 52.5 - 52.9 at startup in the morning. just means it needed another 30 minutes and my timer cut off too soon. this usually happens when I take an alternate route home or to the office due to traffic or construction adding another mile or 2 to my normal commute.
like you I commute to/from work 4-5 days a week on my bike.
understood. smart outlet would be the solution there.The solution for work I settled on is just a 24 hour mechanical timer set to 6 hours ON. At our office we are very environmentally responsible and don't like having phantom loads on if not using them. So this solution Crank it to 2 hours before the timer comes on and unplug it when I leave work. At home this would work 90% of the time. But we go riding at all times of the day and some times twice so I need a solution that works 2 hours AFTER I plug it in for home
@Browneye if you battery does NOT heat up then there is something wrong with YOUR battery. They produce heat while discharging that's just science and physics. Think about it you take 6-8 hours to charge them and then you go for a ride and discharge them in 2 hours. Power going in is no difference from going out and it produces heat. Heat damages a battery and affects its life. Why don't you think you cant just shove 100 amps into a battery and have it charge in 10 min? It's because it would damage the life of the battery so bad it would affect its life. So they decide on on a happy compromise of just enough juice to get it topped up fast without damaging the battery too much. Really we should be trickle charging these batteries over 16-24H or longer to preserve the life of the battery. But this would not be reasonable waiting this long for a battery to charge. Charging the battery when it's hot will reduce it life so instead of getting 500 cycles you only get 450. I ride my bike 5x a week year round to work and charge it from 50% to full at work and same once I get home. This bike is my main transportation. That's a full cycle a day not to mention weekend trips that drain the whole thing. My battery is going to last like 2 years max. To you it's not worth it to others its worth it to get let's say 50 more cycles out of it. This is why I am trying so hard to make it so simple so you don't have to think about it. You do you and us tinkerers will do us. Imagine the world if we just accepted everything for what it was and never tinkered. Imagine we just accepted bikes and didn't tinker with them and put a battery and motor on them. People like us and our tinkering are how things improve for others so they don't have to think about it and just set it and forget it. Please don't discourage tinkerers!
