What size frame did you test out?Greetings all. My LBS let me take the Creo SL Comp Carbon EVO for the day yesterday. Did a 33-mile test ride. Mind you, I'm a heavy guy getting back into road biking after several years away from it. First 20 miles, mostly flat, did not use the battery. Wanted to save it. When I got to some hills, tried all three power levels. Great help. Then I was running late and needed to get back in a hurry. Did the last 5-8 miles in full power mode. My main concern now is that the gear shifting was often not smooth. LBS said it may be that the cable needs to be adjusted after the initial break-in of the bike. Seemed as if it didn't settle cleanly into some of the gears. And with full power, from being stopped at lights, etc., changing gears caused lots of noise. When you start to pedal of course and change gears, the motor tries to kick in, but maybe faster than you want it to, causing gear "crunching." Not sure if I'm explaining it right. Anyway, anybody else experience less than smooth shifting issues? I looked around at some of the other threads, and didn't see one that applied, so posting here. Thanks.
Generally my shifting is smooth, but once in a while I have what you might describe as gear crunching. Usually when I'm going uphill.
Get electronic shifting if you want smooth shifts under pressure. Otherwise let off pressure when you shift. That’s normal, though your test bike may need adjustments as well, which is also normal.
Thanks all. May see if they have a Creo with the electronic shifting to at least try out.I have the same bike and agree it sounds like it is a cable adjustment which is normal maintenance on any bike. Also agree that you want to back off pedal pressure when shifting as that will smooth out the shift.
XL. Felt pretty good.What size frame did you test out?
A word of advice-Don't test ride one with electronic shifting unless you are prepared to spend the extra $. It will spoil you.Thanks all. May see if they have a Creo with the electronic shifting to at least try out.
That made me laugh. Hey, if it's that good, the extra money should be worth it.A word of advice-Don't test ride one with electronic shifting unless you are prepared to spend the extra $. It will spoil you.
Does this really depend on the electronic shifting? Or simply on the higher quality/better formed sprockets? And afaik the problem that shifting suffers much more and makes worrying sounds when you change gears under pressure/while motor is running stays also with electronic shifting. I had a so called "speed pedelec" with more than twice the power of the Creo with Di2 and that didn't change anything for the gears, they where suffering a lot when shifting without a small "pedaling brake". Or is there now some communication between Di2 and SL drive? You put the trigger, Di2 informs Sl drive to stop the motor and the shifting happens some fractions of a second later? If not I don't see any help for this problem with Di2. But the "suffering" of sprockets&chain is much less than with normal/stronger drives. In level1 it's almost nothing, in level2 it's a little bit/needs just a short stop of pedaling. Only in level3 it's quite much and needs a longer break to be nice to your gears.Get electronic shifting if you want smooth shifts under pressure. Otherwise let off pressure when you shift. That’s normal, though your test bike may need adjustments as well, which is also normal.
this sounds amazing ! to @Kenmaryj, my comp carbon shifts cleanly except for some of the shifts into the middle gears, where i have to give it an extra little nudge, but it’s never bothered me. 95% of the time it’s a quick tap on the brifter and i’m into the next gear.I can’t speak to Di2. I’ve never used it. SRAM derailleurs have a clutch to momentarily reduce pressure during a shift. It doesn’t care if the chain tension is from a motor or from your leg. SRAM AXS eTap shifts have always been smooth under tension for me on both my Warroad and my Creo. Doesn’t matter if I’m climbing hills or accelerating. It just works.
thanks! i didn't use any paste since the rails had a scuffed/rough texture finished area at the clamp contact. i need to raise my seat post a bit, will check the level and also investigate the source of the play. it's a very very tiny amount, nothing at all noticeable while riding, just when moving the bike by the seat.Congratulations on the Power Mirror. I don’t have any play in my mount, but my Creo came with the 7x9 clamp already installed. I used carbon fiber assembly paste on the rails.
I was happily riding Selle Anatomica saddles before trying the Power Mirror. I still love them, but the PM is a notch higher on the comfort meter. The saddle that came with my Creo was just a torture device.
Hard to tell from the photo, but it looks like your saddle may be tipped nose down. Try it closer to level if so.
Happy trails
