linklemming
I was able to test fit a 27.5x2.6 smart sam on a 24mm inner width rim/wheel. Definately not the best rim in actual use though but all i had lying around. The tire measured only 2.3 mounted on this rim. A true 2.6 tire would be a really close fit with the wheel all the way forward in the dropout.
Luckily being a horizontal dropout, you can just move the wheel back. Surly sell monkey nuts to make alignment easy.
With this nut, its apparent I could have a much bigger tire as the 2016 redesigned troll can take a 26x3.0 tire so 27.5x2.6 or even 27.5x2.8 tires are in my future. The cantilever brake mounts do get in the way but 1 minute with a dremel and they are gone.
Forgot to mention, I bought a second torque arm from grin so I will make a nicer cleaner torque arm mount.
The GMAC moto does push the rear brake rotor out as far as the spec probably allows. The caliber was at the limit of in/out adjustment so a minute with a file on the caliber bolt holes and the disc is now centered between the pads.
