FlatSix911
- USA
- City
- Silicon Valley
A very interesting review from Electrek... an AWD dual-motor fat bike.
electrek.co
Super Monarch e-bike tech specs
Super Monarch e-bike hits 30 mph with 2 batteries, AWD, and full suspension
At a time when many e-bikes are starting to look like cookie-cutter copies of each other, the new Super Monarch...
- Motor(s): dual geared 500W hub motors (350W motors also available)
- Top speed: 32 km/h (20 mph) from the factory, can unlock to 48 km/h (30 mph)
- Range: 51-93 km (32-58 miles) with AWD and depending on whether using throttle or pedal assist
- Battery: 1x 48V 14Ah (672 Wh) & 1x 48V 17.5Ah (840 Wh) with Samsung 35E cells (1,512 Wh total)
- Charge time: 8 hours with 2A charger (recommended for best battery life)
- Weight: 41.7kg (92 lb)
- Frame: 6061 aluminum
- Front suspension: 120 mm adjustable air shock fork with lockout
- Rear suspension: DNM adjustable air shock with lockout
- Tires: 28-inch x 4-inch Kenda K-Shield puncture-resistant tires
- Brakes: Tektro Auriga hydraulic disc brakes with front 203 mm rotor and rear 180 mm rotor
- Extras: LCD display with speedometer, wattmeter, battery gauge, PAS level indicator, odometer, tripmeter, light status indicator, front and rear LED lights, 9 PAS speed settings, left-side thumb throttle, Shimano Deore shifter, Shimano Alivio derailleur, and an optional accessory list including helmet, gloves, cargo net, rack-mounted tool kit, and two panniers
