I have had the juiced bikes fat tire Ripcurrent S with bafang 750w rear hub motor for 1.5 yrs and now I decided I wanted a mid drive so I got the ultra eagle.
Has anybody else came here from a rear hub bike and switch to a mid drive? I feel like it's going to take me a bit to get used to. The main thing is how the motor drops rpms and you feel that slight pause when you change gears. It's kind of annnoying. With my rear hub motor there's no kind of delay or pause or nothing between changing gears. I can go from a stop and speed up quickly and "click, click, click" all the way up to 9th gear right away.
With the mid drive when I want to take off fast from a stop and I want to change gears in the same way Im used to with the rip current it's like "click" "pause" "click" "pause". So it's kind of annoying even though I am going way freaking faster on the ultra eagle than my Ripcurrent but it's just kind of weird it's like somehow with hard pedaling I reached those speeds and was in the right gear. The torque is pretty crazy but I just seem to get annoyed with the pause between changing gears because I'm used to changing fast like before I could change the gear into low gear right when I reach the steep part of the hill and go up it but with the mid drive you have to change gears way before otherwise if the motor pauses on the steep part of the hill the bike will stop basically.
I don't want to give up on it like I said maybe I just need to get used to it or find a different style of changing gears for the mid drive. I do notice during a gear change after the pause it picks up way more speed all of a sudden. It doesn't really feel "natural" though like it does on the rear hub with the mid drive you definately know it's the motor (if that makes any sense).
I just got it a few days ago so like I said getting used to it but another thing I noticed again not sure if it's just in my head but I feel like when I stop pedaling on the mid drive it's like my speed starts dropping much more quicker than on the rear hub which feels like when I stop pedaling I can keep coasting for longer. I don't know if it's because the Ripcurrent is 4" fat tires or maybe it's the 52t chainring? Not sure if that has anything to do with it. Or just the fact the rear hub being in the rear tire it kind of "pushes" you so you are coasting on momentum? Does that make sense?
