Hi there All,
The PNW Coast Suspension Dropper Seat Post, External Routing, PNW Puget 2x lever is in place. The work was so simple for the LBS they only charged the equivalent of US$15 (still some money in Poland but the indication is they did not sweat at the work)
To get the seat down, you are expected to be seated. Simultaneously pressing the lever (I have had it installed under my left thumb to keep the right palm free for braking) and quite energetic downward push of my
derrière makes the seatpost move smoothly to the lowest position; it is very easy to stand on the ground on whole feet while seated. Getting on and off the bike is now very comfortable, especially getting off. When starting the ride again, you just stand on the pedals, hit the lever and the saddle is at the right height instantly; still a smooth movement so you are rather not hit in the crotch.
The mechanic inflated the suspension to 250 psi (the average of the recommended 200-300 psi) since the guy had no idea what effect the pressure would have with my body weight -- he didn't seem very experienced with suspension posts (but he can understand what to do with the air-spring suspended fork very well). I have no impression how good the seat suspension is with the PNW Coast. Mind you, my Vado's fork is the rigid one. I was intentionally riding the rear wheel into potholes
and I didn't suffer. There was no bouncing ("suspension bob") of the seat-post I could feel (which is good - a spring suspended saddle normally "bobs" under your buttocks) . The mechanic was explaining me the PNW seat-post shock certainly works on the principle of the "Brain" technology found in Specialized shocks: Once the road is smooth, the shock remains rigid; when you get onto potholes, roots, stones, the shock absorber activates.
So far I am happy. The greatest pleasure is the convenience of the dropper seat-post; unless I forget lower it before stopping. It is quite hard to lower the seat just using a hand (you have to push the seat energetically to make it drop).
PNW Coast in the low position.
The PNW Coast in the riding position.
Standing in the "ready to ride" position, as if waiting for the signal change.
Tygra the cat is still in the hospital; I will keep you updated!
