quasimodo
Hi Folks: I installed a 1000 watt front wheel motor kit on a Schwinn Meridian 3 Wheeler and built my own 52 volt battery from used 18650's. (14s8p) It worked great for a month or two then it quit on me, no power showing on the on off button next to throttle. After I got it home, I checked battery voltage and it was ok. I have a connector that is between the controller and battery so I can disconnect the battery when I want. I plugged the connector back together and turned the power on and it worked. I tried riding again and it would do the same each time but would come back on each time I reconnected. I thought it might be the connectors, so I changed them. Same thing. The motor kit is one of the cheaper imports and it runs great when working. Just wondering, before I start looking again for the culprit, if someone else has had this problem and might shorten my diagnosis time. Thanks .....
