Here's one bad connection scenario.
A bad connection could knock one of your series strings from 8P down to let's say 5P. Now that string will deplete faster than the other 13, and maybe it's just a half volt lower. As soon it hits 2.8-3.0 volts, battery shuts off. Other's are at 3.6V,
When you charge it, the charger shuts off as soon as one of the other groups hits full charge (4.2V) and that 5P group cannot not catch up. So it will go out early again and shut the battery down. EVen if it does catch up with balance, it will go out early. ALl of this assumes none of the other cells work loose.
While Tom can make his Vruzend work, I've seen a few posts in other forums where the owner had the connections popping loose. Usually the bigger packs are hard to keep in tune.
