So today was a very interesting day, I charged my battery fully and got everything ready to go and my bike would not work!!! Thanks to Snokid on p31 and Hovtech on p35 I managed to figure out that 2 of the 20 settings were off. The important one was #20 which is the "communication agreement" which I had somehow set to 1 and the default is 0. This was giving me a E-030 code and nothing except the display would work. After I figured this out I had another code, E-008 which turned out to be the wheel diameter. With this code everything worked except for the odo. I had changed this setting over to 22.2" as per the measurement posted by Bxg on p11 but it seemed to create a problem since I had also changed to kms instead of miles but it all worked out okay when I changed everything back to default and then changed one thing at a time and followed Darceman's advice on p31 to press both the up and down arrows to back out of the settings menu which saves your settings. After this I finally got to start my ride but 12 kms into the ride my pedal fell off! I could not put the pedal back on since threads were damaged so used throttle only to get back home, love that option! I re-tapped the threads and tightened it up using Loktite this time (on both pedals, the other one was still tight) and checked it a few times during my ride and it has stayed tight so far. After all of this my ride went pretty good but I will have to adjust the derailleur since the shifting is wonky and it sometimes shifts by itself or I have to go up and down a couple of times to find the gear I want. After a while I just stopped shifting and used the PAS settings and the throttle and had no trouble at all. The brakes now work better so I think they just needed to bed in a bit, maybe there was some crap from the factory that was interfering with how they are supposed to work? I had planned to ride until my battery died but only made it to 36kms when I ran out of time and had to quit. (this does not include my earlier 12kms, the 36 kms was starting out with a fresh battery) During this ride I used the throttle almost exclusively for starting and used mostly level 1&2 for the first part of the ride but went up to level 5 on some hills. When I saw that I was running out of time faster than I was running out of battery I started to use
level 3 and after I got home I still had 4 bars left. Not very scientific for distance but if enough of us post our mileage we can get a pretty good idea of what to expect from these bikes. Other things I did today was install my mirror and add white reflective tape over the
Lectric branding, both for side safety and to make the bike look a little less like an electric bike. One of the features that I like about this bike is the hidden battery since it is too easy to rip off a battery that is in the open on your frame, it also makes it look more like a folding bike and maybe not so much like an electric bike so maybe it won't be such a target for theft? One can always hope and dream! I also put 1/2" closed cell foam on the end of my battery which stopped the rattling on my bike. I tried to use the plastic piece from the packing box like Darceman did but couldn't get it into the frame with the battery, maybe our frames are a fraction of an inch different in size? The next things I added were my water bottle holder from Dollerama and my panniers. These panniers are tall enough to hold our battery and are completely waterproof as they are made of rubber and are built like the dry bags you use for kayaking or canoeing. These are the Rhinowalk 25L bags from Amazon and at $55 bucks are quite the steal (in my humble opinion). One other thing, my paint seems to be very poor quality and easily chips off whenever something hits it or even when I am locking it up with my rubber coated lock. Has anyone else noticed this?
