Lectric XP Dual Battery
jtranger
I just purchased a used Lectric XP Premium with a dual battery setup. Can I just use the bike with one battery and leave the auxiliary removed. Thanks
Yes, there is a circuit that takes the power from the battery with the highest voltage. Since the one battery is is missing the circuit sees 0v and takes the power from the mounted battery. You just won't have as much range with just one battery and it will run out of power sooner than using both batteries. The circuit lets you run two batteries with different levels of charge until the one with highest charge draws down to equal the other, then power comes from both.
